JMB RetrofitsSky Insurance
    Apr 2010
    Radio Reception Problem - HELP!
    Hi,
    I have a Audi A3 Sprotback with a Symphony 2 headunit, I have a issue with my radio reception.
    The radio reception has always been poor since I got the car 2 years ago, but was okay.
    I have just installed some amplifiers in the boot running off the original headunit via it pre-outs. Now when I turn the system on the radio reception goes completely but is slightly better with the boot lid open. Having read other posts on here I had the rear screen replaced yesterday (3 of the lower elements were not working and looked damaged), but this has not fixed the radio reception issue. I have scanned for fault codes and everything is clear.
    I am guessing I need to replace the diversity amp, upper screen amp or diversity selector. This could obviously get very expensive if I replace these and the problem still persists
    Any advice would be greatly received!
    Thanks,
    Nick
    27,108
    Welcome to the site Nick
    What year is the car & does the head unit have silver knobs?
    Apr 2010
    Hi,
    Thanks for the reply!
    It's a 2006 A3 without chrome knobs, to my knowledge it the original radio for the car. I intend to upgrade to the RNS-E at some point and understand that my antenna setup should suit this (8P4035225A and 8P4035225B) but as the radio doesn't seem to work I want to get this fixed first. It would appear the aerial is picking up interference from my amplifiers (these are high end Audison Thesis amplifiers).
    Any ideas? I am toying with ordering both aerail amps, but it could also be the selector or cables! Should I see faults when I scan with VCDS?
    Cheers,
    Nick
    27,108
    I would wire a speaker direct to the head unit front speakers input, remove fuses to the rear amps & then test antenna system.
    I hold those amps in stock for repairs I do on site, I also have some mk1 rns-e's for sale for a good price, so maybe I could look at your issues at same time as upgrade head unit?
    PM if of interest.
  1. allroad C5 radio reception problem
    By Herald in forum In-Car Entertainment
    Last Post: 18th December 2010, 16:53
  2. Help Needed Radio Reception Problems
    By McGart in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th July 2010, 20:18
  3. Radio reception problems after RNS-E retrofit.
    By nectop in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 22nd April 2010, 07:37
  4. Radio Reception Problems
    By Jimbo.King in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd January 2010, 13:26
  5. Radio reception problems
    By karlharcourt in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th October 2009, 08:28
