    Eeef's Avatar
    Lord of War
    Nov 2004
    South Coast, land of the white man
    1,602
    Realtime info via ODB2
    This has been on before but a lot of the newbies might have missed it.
    http://www.vitalengineering.co.uk/
    Essentially info from the OBD2 port, broadcast via Bluetooth to your PDA. Very cool if you've got 199 spare. Software is open source too if you want to write your own apps.
    Jan 2004
    York
    1,640
    Re: Realtime info via ODB2
    do you reckon you could interface the output of the software into vagcom ? Looks like is only one way though ?
    Eeef's Avatar
    Lord of War
    Nov 2004
    1,602
    I doubt it as the vag-com software is a compiled package. You could write something yourself though wit hthe open source software supplied...
    synthdood's Avatar
    Oct 2004
    Amsterdam, Netherlands
    284
    Very cool indeed.
    Now, if this was also available for the CAN bus and for a good price, I might be tempted to write an application for my PDA that I can use to change those settings that should have been configurable from the trip computer/DIS in the first place. Stuff like auto locking, alarm beep, dash illumination, main lights allway on or not, etc..
    The way things are now it is a trip to the dealer and about 60 for each setting that I want changed. The CAN version of VAG-COM is also way to expensive for the things I would want to use it for.
    Jan 2005
    London
    70
    Anand from the 8L forum was writing some software for this months ago. Not sure if he's still on the case.
