Volks AutosChris Nott
    autolatry's Avatar
    Jan 2013
    Yorkshire
    347
    Compression test results
    I finally got round to pressure testing the car today. The results are bad, very bad.
    Cylinder 1 - 185psi
    cylinder 2 - 98 (110 wet)
    Cylinder 3 - 99
    cylinder 4 - 155
    cylinder 5 - 130
    cylinder 6 - 125
    Does anyone know what the pressure should be?
    Im going to get the HG and chains replaced in any case.
    Rom
    Rom's Avatar
    May 2010
    Bristol
    442
    Dont have access to the specs they should be, but clearly yours are down.
    As a rough idea, 150 ish is normally ok (on engines ive worked on), but again, i dont know what the specs for yours should be, obviously different engine designs specify different specs.
    A wet test is mainly to test the rings. As thats what the oil will coat mostly.
    Not knowing what happened, or whats wrong, id say HG leaking between cylinders 2/3. Assuming you haven bent valves etc, but you would know about that.
    A Leak down test is also worth while.
    Sure someone with better spec data will be along soon.
    VCDS - Hex-Can-USB - Bristol Area
    Toyota Pro Tech - PM me if you need something done!
    2004 A3 TDi Sport
    - Bose, Leather / Alcantaras, Cruise, Eibach Sportlines, S Line Facelift
    Full Paint Correction
    To Do - Lamin X, Tints, Wheels
    Past Cars
    Peugeot 205 Gti Mi16 - Main love affair - Build Thread
    Honda CRX SiR - Short lived - Build Thread
    BMW E46 330d Sport
    Peugeot 306 Hdi DTurbo
    VW Gold MK4 TDi
    Vauxhall Nova SR - First car!
    autolatry's Avatar
    Jan 2013
    Yorkshire
    347
    Thanks. I was going to wet test all the cylinders but it was very difficult to get the oil in without it running down the side and taking crap into the cylinder.
    I assumed the HG had gone due to the watery piss that is my oil.
    The cars just turned 100000 miles now. If I'm getting the head taken off it's probably worth changing the rings as well?
    The timing chains going to get done at the same time and the clutch and DMF were replaced a few months ago. So hopefully once this works done I should be able to keep it out of the garage for a few years.
    Rom
    Rom's Avatar
    May 2010
    Bristol
    442
    Rings are a lot more work on top of the head gasket. Means removing sump and baffles, undoing all conrods, removing pistons, fitting rings, and reinstalling.
    2004 A3 TDi Sport
    Past Cars
    BMW E46 330d Sport
    VW Gold MK4 TDi
  1. Compression test results.....reasonable?...
    By JonBoi21 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st August 2011, 13:49
  2. Compression Test advice please.
    By Shy19s in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th July 2008, 11:56
  3. 1.8T compression test (values)
    By luis.filipe in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd October 2007, 12:51
  4. compression tests
    By theitalian3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th April 2007, 16:31
  5. TTC180 road test results anyone?
    By Mikiew in forum TT/TT-S/TT-RS Forum
    Last Post: 22nd June 2003, 20:51
