Sky InsuranceChris Nott
    Jan 2013
    14
    Comfort control module
    My uncle has an A3 2.0tdi (2005) which has an error 00470 to do with the comfort control module
    can anyone tell me where it is located?
    26,777
    Drivers side rear quarter behind the side panel.
    Jan 2013
    14
    Do you mean the panel in the boot or the one inside the back?
    26,777
    The boot.
    Jan 2013
    14
    Ok thanks a lot
  1. Comfort Control Module - are they all the same?
    By Toby_S in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 18th June 2012, 23:54
  2. Where is the Door Warning Lightsd Control module!?
    By GSB1 in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th July 2006, 09:15
  3. Can Airbag Control Module be repaired rather than replaced?
    By Rhunster in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th July 2005, 15:29
  4. HELP! ignition control module!
    By imported_tristram in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th October 2004, 21:55
  5. removing climate control module
    By DrX in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th September 2003, 08:30
