Badger5JMB Retrofits
Results 1 to 12 of 12
    SCHOLESY83's Avatar
    May 2012
    42
    IS THE FACTORY FITTED EXHAUST STAINLESS OR MILD STEEL
    Hi,
    Does anyone know if standard exhaust on the S3 is stainless steel? 2007 model in particular?
    With the price of it, one would assume it is!!
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,785
    I have a full system from a 3 door 2012 S3, its done less than 1k if your interested.
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    SCHOLESY83's Avatar
    May 2012
    42
    Cheers. Will PM you if I go down that route.
    as for my original question, any ideas??
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,785
    mild steel, it's heavy....very heavy...
    Where as my Milltek was not...
    SCHOLESY83's Avatar
    May 2012
    42
    Going slightly off topic but how have you found the miltek? Any issues?
    oh and Audi service technicians says the standard exhaust is Stainless..... Hmmmm
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,785
    It's well heavy, I'm certainly no metal expert, but it's not shiny like the millteks, so I assume it's mild steel. Probably very wrong.
    As for the Milltek, Sounds good, but welds on the downpipe are almost certain to crack at some point and need re welding.
    Boon's Avatar
    Sep 2012
    South East Kent
    405
    Mild steel is magnetic wheras stainless is not... try a magnet on it
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,785
    just did the magnetic trick.
    All the pipes are not magnetic.
    All boxes are.
    So semi Stainless??
    Rom
    Rom's Avatar
    May 2010
    Bristol
    444
    Id think Audi use stainless for the exhausts. Toyota have done for years (apart from Aygo) so surely Audi would.
    There are many grades of stainless though, which is why they wont look like an aftermarket system. They use a higher grade, which is shiny. Obviously OEM are just interested in it lasting a long time, not looking shiny.
    Thats why exhausts are a lot less common to replace on more modern cars.
    VCDS - Hex-Can-USB - Bristol Area
    Toyota Pro Tech - PM me if you need something done!
    2004 A3 TDi Sport
    - Bose, Leather / Alcantaras, Cruise, Eibach Sportlines, S Line Facelift
    Full Paint Correction
    To Do - Lamin X, Tints, Wheels
    Past Cars
    Peugeot 205 Gti Mi16 - Main love affair - Build Thread
    Honda CRX SiR - Short lived - Build Thread
    BMW E46 330d Sport
    Peugeot 306 Hdi DTurbo
    VW Gold MK4 TDi
    Vauxhall Nova SR - First car!
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,047
    Stainless classification starts with 12% Cr content.
    Most exhausts are `18/8 grade` (18Chrome/8Nickel) which are Austenitic.
    Generaly 304 designation for exhausts.
    Milltek gives big gains but welds can crack.
    Make sure your warranty is sound.
    Spicy pizzas n garlic sauce work well.
    good luck
    Now:
    -MK2 Golf Gti 16V/VR6, Oak Green, Shrick, Intake, Decat, Kish Retrim, Lenso BSX..
    -BMW 335d Xdrive, Estoril Blue, fully loaded.
    Before:
    S3 (8P), Ibis, DSG, Milltek, SHARK
    BMW 320d M Sport
    S3 (8P), Sprint, REVO, H&R Springs, BBS CHs,
    Golf MK5 GTi 20TFSI - REVO Stage1, Red.
    Golf MK5 GTi 20TFSI - Std, Shadow Blue
    Civic Type `R`
    Golf MK4 GTi 18T - 200bhp, MTM ECU, Forge DV
    Golf MK3 VR6 - Cat Back
    Corrado VR6 - JAMEX
    Corrado G60 - JAMEX, BRM Charger rebuild
    etc....
    SCHOLESY83's Avatar
    May 2012
    42
    Did the magnetic check too, I found that all pipes and both large boxes (mid & rear) were non magnetic - suggesting stainless. Cat and smallest box as well as the chunky bit straight after turbo connection were magnetic - suggesting non stainless.
    Thanks for your input guys.
    SCHOLESY83's Avatar
    May 2012
    42
    Disappointing to here about the Milltek cracking issue. Surely this is covered by their corrosion and manufacturing defect warranty??
  1. are factory fitted s3 Exhausts stainless steel?
    By epox in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th February 2013, 10:59
  2. S3 Factory Fit Sat Nav- Cleaning the screen??
    By elgan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th December 2010, 00:40
  3. Who has the best factory fitted options
    By lionyo in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 18th November 2010, 07:08
  4. How to remove the factory fitted phone cradle?
    By ntp in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 15th October 2009, 19:25
  5. The standard factory fitted A3 alarm (HELP)
    By Vikz in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th July 2006, 19:51
