JMB RetrofitsSky Insurance
    Jan 2013
    99
    DPF Regeneration?
    Hi folks,
    Tonight I had a strange experience. I was out speaking to some friends in my car (170 tdi). I went for a quick drive to the local tesco (through a village, never went over 2000 revs).
    I then sat with the engine off for roughly half an hour. Upon starting the car up to head home several comments were made as to the idle being rough, more oil was suggested however no oil light was on and I checked the oil at start of week and level seemed normal. Also there was a bit of smoke from the exhaust and a horrible smell, hard to describe but toxic might be close.
    From reading different things online tonight, I wondered if it was a possible DPF regeneration, however I was not aware that this could be done upon start up or if the smell I described matches a regen. Is this possible?
    Also as it is a 170 I believe there is a recall for the injectors, could this be the possible cause of the rough idle and smoke/smell?
    Hoping it is something like the DPF regenerating or injectors! Anything else and I think I might sell up for a petrol (I have only owned the diesel a week!!)
    Justin
    27,072
    Sounds like a dpf regen, relax, see how is over the weekend.
    Jan 2013
    99
    Thanks for the quick reply bud! I'll keep an eye on it and see how it is. Definitely feel more reassured now!
    Oct 2012
    29
    Yup... dpf regen.
  1. Could this be a DPF regeneration?
    By Jeeves in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 6th September 2012, 22:38
  2. Replies: 0
    Last Post: 8th August 2012, 11:13
  3. dpf regeneration with vcds ?
    By vw754 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 18th October 2011, 20:35
  4. Remap of 170TDi DPF Engine
    By JED in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th August 2007, 20:25
  5. Audi A3/Sportback 2.0 TDi (DPF)
    By dorgan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th June 2005, 22:01
