Volks AutosAH Fabrications
Results 1 to 17 of 17
    JRock247's Avatar
    Jul 2012
    Hampshire
    315
    2006 Audi A3 S-Line 2.0TDi Steering Wheel upgrade
    Hi Guys,
    Recently purchased an Audi A3 2006 2.0TDi Quattro S-Line 3 Door and I am in the process of upgrading a few bits and bobs. I am looking at getting a MFSW from a 2009 Audi A3 (PART NUMBER: 8R0 419 091 FTNA) but I am not sure if the Multi-Function part of the steering wheel will be compatible with my car (car currently has a non-MF steering wheel). I read on some forums you need the 'highline' ECU version for the MF's to work, is this correct? How do I know if I have the highline version or not? Also, the new wheel does not come with an airbag but from my understanding, I can use my current airbag, true?
    A few details of my car, I have DIS, RNS-E Head Unit (Upgrade from Symphony 2 Unit), Non-multi-function S-Line 3 spoke steering wheel, 2006 registered vehicle, No cruise control (would like to add it though).
    Please let me know if you need any further details from my car to better answer my questions.
    Thanks in advance guys for your help, much appreciated.
    Jamie
    leeds2592's Avatar
    Apr 2012
    Leeds
    996
    You're correct, you'll need a highline steering ECU for the MFSW to work. You'll probably have a midline ECU but best way to check is to do a scan with VCDS or take the wheel off and look manually.
    I've just fitted the same MFSW to my 57 plate and my airbag and slipring were fine for the new wheel, so think you should be ok. Hopefully someone confirm 100% though.
    And if you're fitting the MFSW yourself, you may as well fit cruise at the same time whilst the wheel's off.
    Black 2007 2.0 FSI Sport
    2011 Glossy Black RNS-E |AP Coilovers | 18" 7 Spoke OEM BE Alloy Wheels | H&R Trak+ Spacers 8mm (Front) 12mm (Rear) | MY11 Rear Lights | S Line Spoiler | Retrofitted MFSW | Retrofitted Cruise Control | Interior LED Light Pack | OEM LED Numberplate Bulbs
    JRock247's Avatar
    Jul 2012
    Hampshire
    315
    Thanks for your reply leeds2592.
    So you have fitted the same wheel to your car, how did it go, any issues or anything I should look out for when installing mine? I am a little worried about the airbag, don't want it going off in my face!
    I will take of my current wheel and see which ECU I have, will is state 'midline' or 'highline' or do I need to look for a certain part number relating to 'highline' versions?
    If I have the 'highline' ECU, will that not involve any coding to use the MFSW buttons? (coding recquired if 'midline' version?)
    Thanks again for your help.
    JRock247's Avatar
    Jul 2012
    Hampshire
    315
    Oh and I don't have the Cruise control unit yet, hopefully in a months time or so, when I have saved the penny's!
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,289
    you need this part Audi A3 8P 2008+ Steering Combination Module 8P0953549F *FREE P&P* | eBay
    thats the highline module.
    If your car is a dsg then it already has it, slim chances of it already being there in a manual car
    you may as well put in cruise at the same time as the MFSW.
    pm me if you need someone to do it for you
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Lights Pack
    MODS:
    S3 facelift, 19" RS6, RS3 Grill, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, S3 brakes, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, Auto Folding & Dimming Dumbo Mirrors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    Items for Sale
    Read My Blog & Build Thread
    leeds2592's Avatar
    Apr 2012
    Leeds
    996
    I had no problems really, other than getting the spline bit undone as it was on bloody tight. I followed this guide Cruise Control Retrofit Guide. Before you start messing about with the connectors on the back of the airbag, the battery is disconnected so you don't have to worry about it going off.
    It won't state highline on the ECU, you'll need to look for a part number. The number you want to see is 8P0 953 549 F, not one beginning with 1K0. Although, if you car is DSG it will probably have it.
    Unfortunately it doesn't work that way. A MFSW just won't work with a midline ECU, whether it's coded or not, you need a highline ECU. It then needs to be coded which is pretty easy tbh.
    You'll also need a new airbag wiring harness for the MFSW, part number 8P0 971 589 AD (or 8P0 971 589 AB) can't remember which but it's around £41.
    JRock247's Avatar
    Jul 2012
    Hampshire
    315
    Quote Originally Posted by Ash187 View Post
    Are you sure that will fit my car as it states 2008+ and my car is a 2006 model.
    My car is a manual, so most likely doesn't but will double check anyhoo.
    I think I will fit it when I get the Cruise Control kit, seems like the logical thing to do.
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,289
    yes it will fit your car, its listed wrong.
    as you can see leeds2592 has said that same part number as i have, do a search on the forum for that part number and you will see that this is the only module for MFSW to work on cars before 2009, after that they changed to a steering module with the part number ending in K
    A3 Sportback 2.0TDI
    MODS:
    Items for Sale
    JRock247's Avatar
    Jul 2012
    Hampshire
    315
    Quote Originally Posted by leeds2592 View Post
    Thanks for the info
    Is that part number definitely correct, I found this on eBay with a very similar part number (see images for part number as description is incorrect)
    Audi A3 8p Steering Airbag Wiring harness 2005-2012 | eBay
    If not, do you know where else I can get one from?
    Thanks again guys
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,289
    Quote Originally Posted by JRock247 View Post
    Thanks for the info
    Thanks again guys
    that one on ebay is for cars without MFSW as there is no lead on that harness to connect to the MF buttons
    A3 Sportback 2.0TDI
    MODS:
    Items for Sale
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,289
    AUDI TT MK2 2006 - 2012 AIRBAG SQUIB SLIP RING WITH AIRBAG WIRING HARNESS A3 A4 | eBay this one may fit your car but cant confirm as no part number listed
    A3 Sportback 2.0TDI
    MODS:
    Items for Sale
    JRock247's Avatar
    Jul 2012
    Hampshire
    315
    Oh, OK thanks for the heads up. I will keep hunting then!
    Any idea where I might be able to get my hands on a second hand one, other than eBay?
    JRock247's Avatar
    Jul 2012
    Hampshire
    315
    Saw that one myself, just messaged the bloke for the part number.
    Thanks again guys, really appreciate your quick response to my questions, wish Audi was as helpful! HA
    leeds2592's Avatar
    Apr 2012
    Leeds
    996
    Easiest just to get a brand new one from Audi like I did.
    I'll confirm whether its AD or AB when I get home, just at work at the moment.
    JRock247's Avatar
    Jul 2012
    Hampshire
    315
    Probably would be easier but trying to keep costs down as much as possible, any idea what Audi charge for it, knowing Audi, EXPENSIVE!
    leeds2592's Avatar
    Apr 2012
    Leeds
    996
    Just checked mine an its 8P0 971 589 AD you want, cost £41 from Audi.
    JRock247's Avatar
    Jul 2012
    Hampshire
    315
    Hi Guys,
    Just wanted to say many thanks for the advise/info above for my steering wheel upgrade.
    Installed the new MFSW and Cruise Control on the weekend and all went very well. The guides I used on this site were brilliant and helped hugely. Easy to follow and experts on call in the forums if you get stuck.
    Just a small note for anyone else attempting this, when I did mine, I had to replace the steering ecu and subsequently after the install I had very little power steering input, no esp and no abs untill I get them coded (tonight), just a heads up guys. You may want to have coder ready and waiting when you have done the install.
    If anybody is about to complete either install, PM if you need help or advice.
    Thanks again guys!
  1. Audi A3 S-line 2.0TDI
    By Smoothie in forum For Sale/Wanted - Audi Cars
    Last Post: 24th June 2011, 13:18
