Chris NottSky Insurance
Results 1 to 14 of 14
    tdi-man's Avatar
    Jul 2009
    1,589
    do i need a remap after engine rebuild
    engines had new head fitted and new piston rings shells etc etc
    do i need to get it remapped again ?
    thanks
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs / Oil catch can
    233 bhp - 309 ft lb - 419 nm
    FLYWHEEL + HELIX CLUTCH KIT FOR SALE
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,988
    if you had a map it will still be there in the ECU
    May 2012
    York
    216
    Well surely your engine will run better now so you'd have thought you'd possibly be able to get more out of it now - so id suggest yes.
    maybe wrong tho
    tdi-man's Avatar
    Jul 2009
    1,589
    lol i know that just wonder if i need it checking
    bez101's Avatar
    Jul 2008
    7,988
    it wont need checking
    rebuilding engine wont change the map.
    May 2012
    York
    216
    Of course the map hasnt changed but in theory the engine has
    bez101's Avatar
    Jul 2008
    7,988
    unless its a full on custom map it would only be the ame if it was reflashed
    tdi-man's Avatar
    Jul 2009
    1,589
    it is a custom map with a hot start fix in the map and i was wonder if the hot start probelm was down to the fact that the cracks in the head are in the glow plug holes
    bez101's Avatar
    Jul 2008
    7,988
    dont worry about it
    so you have a stage 1 remap
    i ment a full on big turbo stage 3 custom map
    it will be ok
    tdi-man's Avatar
    Jul 2009
    1,589
    i do have a hybrid turbo with full egr delete
    bez101's Avatar
    Jul 2008
    7,988
    so i take it you still have ther same set up nothings changed
    then you should be ok
    but by all means spend some money for the fun of it
    when i had my stage 3 rebuilt with new cams and head both times the map was still the same
    tdi-man's Avatar
    Jul 2009
    1,589
    i was wondering if mine had a hot start fault ie not start first turn of the key when hot if these cracks by the glow plug holes might of been the cause ?
    so i could get the hot start mapped out
    http://i1000.photobucket.com/albums/...ps81673b23.jpg
    TDI140's Avatar
    May 2011
    1,293
    Map is programmed to ecu so should be all there but worth getting it tweaked for your new built engine as all components are new and will be working much smoother that way you might get more bhp
    A3 2.0TDI FWD sportback with GT1756 225bhp 351ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch
    Boon's Avatar
    Sep 2012
    South East Kent
    354
    Quote Originally Posted by tdi-man View Post
    You say you had a hot start map done so was the hot start rectified with this?
    I also have had a hot start map replaced/tweaked and mine has been brilliant, neither the starter or battery has been changed. (Anyone with a hot start issue should unplug the temperature sensor located under the fuel pump when at operating temperature and start the engine - if it fires up just as cold, the starter nor the battery are at fault - it's the software in the ECU)
    Oh, and your Remap will stay on the ECU, I fail to see that getting it tweaked because the engine is rebuilt will bring any gains (apart from being stronger/last longer!) Just remember to 'run it in'!
  1. Engine rebuild advice needed
    By patTTpoa in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th November 2011, 20:52
  2. Do i need to tweak my remap after fitting a FMIC
    By s3 man in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th March 2011, 15:59
  3. New and need help - any contacts for an S4 engine rebuild
    By grgh in forum The Welcome Section
    Last Post: 14th March 2008, 19:30
  4. Advice needed on remapping an A3 2.0T Quattro
    By nb in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st October 2006, 01:02
  5. engine rebuild?
    By SQ_lover in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th August 2005, 01:43
