AH FabricationsBadger5
    miw615's Avatar
    Feb 2013
    Surrey
    446
    OIl / Service Question
    My car has Castrol Edge Proffesional oil in it - last changed 2000 miles ago in August 2012. My dealer says that it requires an oil change this coming August, by then it would have covered only 4000miles since the last oil change - the service was an "inspection service" - sounds a bit strong to me. questions............
    1. Surely the oil can last for another year so it would be changed at approximately 8000 miles - problems?
    2. Is this oil used for both the inspection service and the long life service and what is the difference between the two services?
    3. What is the difference between the Castrol 5w 30 oil and Quantum 5w 30 (made by castrol I understand?) - can I run my car
    on one type all year round no matter what service interval I take?
    4. Given that my mileage will be between 6000 -8000 miles a year what service plan should I follow and with which oil?
    Because of my low mileage all my other cars (three Mercedes) - (petrol engines) have their oils changed every two years regardless of mileage (which is between 1500 - 3500 miles per car per year) so is there any reason why the Audi can't be the same?
    Thanks in advance for replies
    miw615's Avatar
    Feb 2013
    Surrey
    446
    Anyone - please
    Malcolm
    Audi A3 2.0 TDI S-Line Sportback
    Rom
    Rom's Avatar
    May 2010
    Bristol
    444
    Modern oil can last a lot longer than a year.
    Only you can decide if you want to change it though. In all reality, its going to make no difference. So many cars go without oil changes. As long as the level is ok, thats most important.
    Personally, i always change my oil every year. But i only pay for the filter Oil rep told me i was wasting good oil (previous high performance petrol engines, sub 5k a year running Mobil 1 0w/40 fully syn) said it hadnt even started to break down and lose performance so no point changing it.
    I dont know the difference between the 2 oils. But theres many different oils, some listed as long life, or fuel economy etc.
    VCDS - Hex-Can-USB - Bristol Area
    Toyota Pro Tech - PM me if you need something done!
    2004 A3 TDi Sport
    - Bose, Leather / Alcantaras, Cruise, Eibach Sportlines, S Line Facelift
    Full Paint Correction
    To Do - Lamin X, Tints, Wheels
    Past Cars
    Peugeot 205 Gti Mi16 - Main love affair - Build Thread
    Honda CRX SiR - Short lived - Build Thread
    BMW E46 330d Sport
    Peugeot 306 Hdi DTurbo
    VW Gold MK4 TDi
    Vauxhall Nova SR - First car!
    miw615's Avatar
    Feb 2013
    Surrey
    446
    Cheers Rom
    Malcolm
  1. Oil change / service question...
    By TQS in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th April 2006, 19:22
  2. Servicing question?
    By jim1965 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th November 2005, 23:35
  3. S3 servicing questions
    By paulwakinshaw in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th November 2005, 23:11
  4. A3 T Service Question
    By RickMcG in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th November 2003, 17:06
  5. 1st Service Questions
    By amlaS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th September 2003, 09:25
