Sky InsuranceChris Nott
Results 1 to 15 of 15
    Feb 2013
    6
    Thumbs up S3 19" Bentley rims tyre options
    Hi Im wondering if any body can advise Me on which tyres I can use on a set of Bentley Rims !! The Rims are 19" 9j (Et 41) and are to be fitted to an S3 8P (2007) .The Rims are fitted with 215/35 19 but wasnt really wanting to run that size of tyre and unless I really had to .I would prefer 225`s or even 235`s,also my plan was to lower the car as well !! Any help on this would be great ...
    Feb 2009
    Aberdeen
    2,491
    235 will rub, and 225 will probably rub too (depending on lowering). 9j is just too wide to run anything other than a 215 with the limited offset range that'll clear the strut and arch.
    Fire N8 a pm and he'll be able to tell you for sure, but I think your options are 215s or rubbing.
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    i run 235 35 19 on scirocco luganos with no rubbing unless i go over a hard bump fast
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    Dec 2008
    278
    Are Luganos not 8J rather than 9J tho - assume this makes a difference in how the tyres will fit under the arches as there will be different amounts of stretch etc.?
    Feb 2013
    6
    Cool cheers MartayMcFly I`ll try and pm N8 and see if he can offer anymore advise ...
    Feb 2009
    Aberdeen
    2,491
    Yeah, pretty sure you can get away with 235 on an 8j just because you can set it further into the arch (higher ET).
    Hunt is over
    Dec 2008
    278
    Quote Originally Posted by MartayMcFly View Post
    Yeah, that makes sense.
    L1ARR's Avatar
    Sep 2003
    Home Sweet Home
    360
    You might get away with 225 on the rear, is the car lowered at all? Remove the screw in the rear arch. The front you might have to run a 215, not too sure if the stretch will be too much on a 9j. They are a good offset which helps your cause.
    N8 will be along shortly or try IanS3
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,791
    Busy trying to squeeze 245x18s under mine at the moment so I can understand the problems above !
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    my luganos sit flush with my arches, look the dogs
    Mods
    Feb 2013
    6
    Well it isnt lowered yet ,but I`ve got Eibach arb`s to fit along with Bilstein coil overs !! Plus you get a better selection of tyres in a 225 than the 215 ...I think the bentleys look quality ,but if Im going to get hastle think I might just end up selling them on ....
    timmythechef's Avatar
    Starin' Through My Rear View
    Jan 2011
    South Wales
    259
    I run 215/35/19s.
    Lowering your car...So its easier for the year 9s to get in
    Feb 2013
    6
    How does the car handle when running the 215`s ,or have you ever tried or heard of anybody running 225`s on a 9j bentley rim ? Also do the bentley rims need spigot rings or longer wheel bolts ,or do the standard bolts do the job ?
    L1ARR's Avatar
    Sep 2003
    Home Sweet Home
    360
    Quote Originally Posted by sinkiABZ View Post
    Log onto Edition 38, you will guarantee to get this answer.
    Feb 2013
    6
    Cool ,cheers L1ARR will do ..
  1. Broken Bentley Rim ! :(
    By Y 14RGE in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th July 2011, 01:32
  2. bentley rims
    By vr6gordy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th June 2011, 15:54
  3. Bentley rims
    By royce259 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th June 2010, 15:02
  4. Wheel & tyre options: OEM or aftermarket copies?
    By warren_S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th July 2009, 00:01
  5. best tyre option opinions 225/40/18??
    By campbell in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th July 2007, 21:55
