EM TuningMonster Motorsport
Results 1 to 13 of 13
    Sep 2012
    39
    Bi Xenon flickering on start up! whats usually the problem?
    Hey guys
    As the title says what could be wrong, its a 57 plate S3 and I just noticed that when I put the ignition on it was flickering, but then cleared after a few seconds. Its like its only on fire up!
    Ash
    27,028
    Could be a bulb or headlight module, is it one side or both?
    Jan 2012
    SW London
    794
    By any chance does it do it around if not exactly 5 times? I get this with my led 501s. Im sure its just the canbus system passing power through to make sure all is working well, although thats aftermarket equipment i doubt the same thing should happen with oem?
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    27,028
    Not with oem bixenons no.
    Sep 2012
    39
    It's just on the passenger side and it is more like a slight flicker rather than a strobe effect!
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,321
    most likely bulb is on its way out
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Lights Pack
    MODS:
    S3 facelift, 19" RS6, RS3 Grill, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, S3 brakes, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, Auto Folding & Dimming Dumbo Mirrors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    Items for Sale
    Read My Blog & Build Thread
    Dec 2008
    278
    When my Xenon bulb started to die it produced a noticeably purple light in comparison to the other one which was still more blue/white - is there any difference in the colour of light between your passenger and driver side lights?
    Pushing the limits..
    Jan 2011
    Australia
    1,307
    Add Sevv on Facebook
    try the bulbs mate most likely or the ballast but i would change the bulbs first
    Sep 2012
    39
    I haven't noticed any difference in the colour of the light and after the first start of the day it seems to stop until its left again for a while. How much is a bulb for these?
    Jan 2011
    Australia
    1,307
    i bought mine of ebay 100 USD i remember.... , i remember one of the member had an issue with the headlight switch in the cabin , check the connection to the switch is fine too
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,308
    From your friendly Audi dealer the bulbs are about £120 and the ballast will make you weep.
    About £600.
    Mine packed in a month ago.
    Dec 2008
    278
    I fitted these to my S3 in January 2011, touch wood they're still fine today.
    D1S 35w HID Xenon Replacement Bulbs (PAIR) - HIDS DIRECT LTD Store
    Non OEM but £30 for a pair. A right bugger to fit mind you - am I going mad or is it a bumper off job?
    The Governor's Avatar
    Mar 2012
    Southampton
    436
    Quote Originally Posted by S3Alex View Post
    About £600.
    £600!!! How can it be that much?? Is it that the ballast is not a consumable and in theory should never go, or is it an inevtibality that it will at some point, because £600 to get your headlights working is obscene...
    [Edit] Ah I see, just did a bit of a check about, ballast is not ballast at all, it's a voltage regulator...
  1. Clutch just randomly started squeaking... What the hell
    By nshort10 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd March 2011, 18:23
  2. Very strange cold start behaviour what do you think ??
    By Duktor in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2011, 20:17
  3. What's the problem here when I cut engine off?
    By vw754 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th January 2010, 15:03
  4. 3 beeps at start up - what does this mean
    By ADP in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd May 2007, 14:27
  5. What could the problem be??????
    By imported_alecblack in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th July 2005, 16:33
