JMB RetrofitsEM Tuning
Results 1 to 8 of 8
    Jan 2013
    99
    Removing front bumper
    Hi guys,
    I know this has been covered and I have found a couple how to's but just have one question.
    I want to take of my front bumper as the passenger headlight appears to be loose at the bottom. I don't have a problem doing this as I used to do it quite regularly on my golf.
    However I don't want to upset the alignment of the bumper in any way when I put it back on. Do you think if I just take my time and follow the step by step guide I won't have a problem?
    justin
    27,099
    If its loose, then just lift bonnet & check the torx bolts are tight, 1 is on top in full view, other 2 are on left/right & down in a hole about 15-20 cm's using something like a T30-35 head bit, before removing bumper & you wont have a problem with shaping.
    Jan 2013
    99
    So I can tighten all of the bolts without removing bumper then?
    27,099
    Yes.
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,402
    Follow Brodster On Twitter Add Brodster on Facebook
    Should have no problem. Ive never seen or heard anyone experiencing mis-alignment problems when refitting the front bumper.
    Angelwax/BBS/BCS/Bilstein/Cobra/CTS Turbo/DTUK/H&R/K-Sport/KW/Loba/Milltek/Shark Performance/Oz Racing/TPI/VCDS/V-Maxx/Vossen/Wagner
    Jan 2013
    99
    That's kl I'll get on that, if I can open the bonnet that is!! Stupid cable! Although I've read up on it so got plenty to try!
    I don't think I've ever heard of misalignment either but just want to make sure, it would just be my luck to ruin it! Ha ha
    thanks guys
    Feb 2012
    Birmingham
    137
    The bumper basically guides itself into position, dont need to worry too much about it
    Jan 2013
    99
    I think I'll see if I can tighten the light up without the bumper off but feel more reassured if I do have to take it off
  1. Removing front bumper
    By J7USS in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th January 2007, 01:23
  2. Removing front bumper
    By Defratos in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st August 2006, 23:44
  3. Remove front bumper, How?
    By OlovM in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th May 2006, 08:05
  4. remove front bumper on a 1998 A6
    By dreddg in forum General Technical / How To
    Last Post: 6th August 2005, 11:10
  5. How easy to remove front bumper?
    By fallmonk in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th February 2005, 22:34
