Volks AutosJMB Retrofits
Results 1 to 7 of 7
    Sep 2010
    31
    Glowplug error 3.2 v6
    Took my car in for a service and a few repairs. Had the bearing changed on rear right and the abs/ESP error lights started to kick in over 60mph so back to the garage it went.
    on the way there the emission control warning light activated too. Plugged in to vagcom on arrival and it said "glow plug error" both me and the mechanic were like....huh! It's a 3.2 v6 and not be mapped to my knowledge.
    We took it for a spin to see what the abs/ESP error lights were for and got "too many errors" to read from sensor message so a new abs sensor is on its way.
    When we got back to the garage there was smoke coming from under the bonnet and he reckons he could spot an oil leak. Any ideas what it could be?
    Weirdly, it's been driving a bit like a turbo recently...picks up like mad at 2k revs don't know if its connected or not?
    thanks for any help
    Jan 2012
    SW London
    794
    Glowplug error on a 3.2 v6....... Petrol....?
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    Sep 2010
    31
    Quote Originally Posted by Sidhu88 View Post
    yup! Totally baffled us both, some googling shows it has occurred on a few petrol engines before but nothing conclusive....
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    748
    Glow plug light on the dash? What was the actual error code in VCDS?
    Rick
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,220
    Check if someone's put a TDi engine in :$ glow plugs and 2krpm turbo pickup hmmmm
    Sep 2010
    31
    Glowplug error in vcds and emission control system error light on. Unconnected but also ESP and ABS error lights on.
    emission light came on after hard acceleration and like I say, smoke under bonnet after booting it with mechanic on test drive to read abs and other faults. Blown coil pack perhaps?
    /edit can't remember actual error code but it was to do with glo plug temperature....
    Jan 2012
    Stockport, Cheshire
    748
    we need to known what the actual codes are, then can look at what's happening. At a guess, leaky breather system is causing an air leak which is why there is smoke and an air leak causing running problems.
    Rick
  1. Error codes!
    By S4ZippyZoo in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th November 2004, 12:43
  2. Flashing error code- "1n 1"
    By randallons in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th October 2004, 12:27
  3. Sat NAv Plus - Error Message
    By mrg in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th February 2004, 14:33
  4. CD-Error 2 problem???
    By Jack829 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th April 2003, 21:30
  5. Errors!
    By A4Steve in forum General Chat
    Last Post: 7th February 2003, 10:17
