Chris NottSky Insurance
Results 1 to 15 of 15
Thread: engine rebuild
    tdi-man's Avatar
    Jul 2009
    1,611
    engine rebuild
    heads come of today
    water pump had a leak so new one will be going in any way.
    Blocks ok so new rings / shells / etc oil pump
    recon head
    question is when putting together is it ok to use gasket sealant on inlet manifold and turbo manifold as well as the gaskets ?
    thanks
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
    Lewis583's Avatar
    Mar 2010
    870
    You shouldn't need to assuming new gaskets are used
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    27,086
    Exactly, just use new gaskets all round.
    tdi-man's Avatar
    Jul 2009
    1,611
    ok cool thought id ask as like a nice seal .
    all new gaskets and seals are to b used .
    thanks
    27,086
    "Be"
    tdi-man's Avatar
    Jul 2009
    1,611
    thinking of fitting a oil can can any advice ?
    27,086
    Fitting a oil can can, what exactly is that?
    tdi-man's Avatar
    Jul 2009
    1,611
    oil catch can .
    27,086
    Typo then.
    Yes, advice is, dont vent to air, check Allard.
    Aug 2010
    160
    Why not vent to air? Apart from being illegal
    27,086
    & thats not a good enough reason for you?
    autolatry's Avatar
    Jan 2013
    Yorkshire
    347
    tdi-man's Avatar
    Jul 2009
    1,611
    The good news is my bottom end is fine
    The Bad news is the head has cracked where the glow plugs come out
    and its a C in the part number
    autolatry's Avatar
    Jan 2013
    Yorkshire
    347
    Are you doing the work yourself?
    tdi-man's Avatar
    Jul 2009
    1,611
    no
  1. Engine rebuild?
    By Lee Goodall in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th December 2008, 00:04
  2. Engine rebuild options???
    By dappadan786 in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th September 2008, 22:27
  3. New and need help - any contacts for an S4 engine rebuild
    By grgh in forum The Welcome Section
    Last Post: 14th March 2008, 19:30
  4. S3 ENGINE REBUILD!!
    By pault in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th July 2007, 09:31
  5. engine rebuild?
    By SQ_lover in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th August 2005, 01:43
