AH FabricationsChris Nott
Results 1 to 30 of 30
    Feb 2013
    Heartland USA
    10
    2007 A4 airbag in 2010 A3?
    Trying to find an airbag to replace my blown A3. Hard to find. The 4 spoke a4 looks the same (badge) as my 3 spoke A3 (badge), but looks are decieving. Search shows a similar thread, but years wheren't posted, so I wanted to confirm.
    Thanks.
    If anyone else want to chime in on what else needs to be replaced, I would apreciate it. Front impact crash, only steering wheel deployed. Haven't checked seat belts yet. I've had car less than week, and purchased it this way. So very new to it all.
    27,089
    Airbag control module would have crash data, so either replace or have it sent away to have the module reset.
    Show us a pic of your current underside of airbag & also front pic, to be sure of advice.
    Feb 2013
    Heartland USA
    10
    My a3 Not sure what you mean by underside, I haven't figured airbag removal to find part numbers and such,
    This is the a4 wheel
    27,089
    4 spoke doesnt fit 3 spoke, remove airbag by using a torx 27 head at rear & take picture of under side where loom plugs into the airbag.
    Feb 2013
    Heartland USA
    10
    How about a 2006 A3 3 spoke?
    27,089
    Ok I'll ask politely for the 3rd & last time, please show us a pic of the bottom of the airbag, there's a reason for this.
    Jan 2012
    111
    Re: 2007 A4 airbag in 2010 A3?
    The oder way U can buy any stering wheel from a3,4,tt with MF and airbag not older like 2007 if is from 3door or any year from sportback.
    27,089
    Quote Originally Posted by daniel.ireland View Post
    Also there are 2 airbag types, which is why he has to confirm which he has by way of a photo, stop misinforming people which then makes them buy an incorrect item.
    Fossie
    Rhubarb Triangle
    3,969
    No you can't Daniel ! That information is incorrect and, as NHN says, there are two different types of airbag that look identical from the top but have a different fitting profile underneath.
    I have two mfsw's one from an A3 and one from an A4 and they require different airbags.
    Feb 2013
    Heartland USA
    10
    Sorry, wasn't ignoring you, I was just able to get it off today. Hre you go. Thanks
    27,089
    With respect, I did say pic of the underside, so we can see the underneath of airbag, not the part number, need to see connections & chassis type of airbag to confirm.
    Jan 2012
    111
    I just said I have same airbag like Hi needs
    Other way is Hi can buy any complete steering wheel from a3, a4,TT or R8, and will be works. Or s3 flat bottom also.
    I didn't said Hi can buy airbag from a4 and fitted to a3 stering wheel.
    Feb 2013
    Heartland USA
    10
    No problem, I'm the one who can't follow directions...
    27,089
    You said you had an airbag available for a price, thats not allowed on the open forum, read the rules!!!
    You mean "HE"
    27,089
    Quote Originally Posted by Unseenthings View Post
    Ok so you do have the different airbag as I thought.
    See those 2 white plastic locating holes to the left & right of your orange/green airbag connectors, those locate into the metal studs inside the base of the steering wheel.
    Audi only used these type for a short period & there was no way to determine which you had until now, so you need to find an airbag that has the same 2 plastic holes if you want to use the same wheel.
    Also your airbag controller will have crash data in that either needs resetting or replaced.
    Fossie
    Rhubarb Triangle
    3,969
    Daniel, I'm not sure of your nationality but your English is better than my attempt at any other language would be !
    However, I think that there may be a problem with understanding exactly what you mean sometimes. It is inadvisable to suggest or recommend certain things when they can be misunderstood, and in the case of airbags and steering wheels particularly so.
    Had you said a 'complete steering wheel and airbag' then that would have been more correct.
    If you have something to sell then you need to put it in the classifieds section of the forum and not this part.
    Feb 2013
    Heartland USA
    10
    Good job Audi.... Suggestions on a complete wheel/airbag swap? A4, TT, etc? That might be cheaper it seems.
    Jan 2012
    111
    Sorry
    Next time I send PM
    I'm not seling any parts just won't help and in that case I wright hire.
    I know my English is so bad. Sorry
    27,089
    Whereabouts are you located in the world?
    Is that an A3 cab?
    Feb 2013
    Heartland USA
    10
    Central USA, Illinois
    2010 4dr TDI
    27,089
    Ah thats a pita as import taxes if bought from EU.
    Jan 2012
    111
    Someone can send Him This as a gift, then is tax free
    27,089
    Very doubt it indeed, you're going to send him an airbag & steering wheel as a gift, chances that avoiding taxes are very remote.
    Feb 2013
    Heartland USA
    10
    Never purchased anything from the EU, what's up with taxes?
    Jan 2012
    111
    I bought many things from US, always send them first to my friend and later to Ireland. I newer pay any penny.
    If U buy something from EU courier charge U vat/tax from the cost of purchase. For example if U buy something for 100$ and tax is 20% courier charge U 20$
    But if private person send You parcel like gift should be without any tax
    Jan 2012
    111
    I'm sure its the same.
  28. #27
    27,089
    Thats the one you have for sale is it?
  29. #28
    27,089
    Yes within the EU its not charged for import, but buying from US to send to UK or vice versa, there is a customs charge, you have been lucky as they dont always charge it, but if you use a courier like ups or fedex, they have a system with customs that they auto add taxes regardless, been there got the tshirt, so I know what I'm saying is true.
  30. #29
    Jan 2012
    111
    Yes that's true, FedEx if You buy on eBay charge tax automatically if purchase is more expensive like 36 euro. But if You send by post to friend, family and You wright it is a gift going for free. Like I said I'm buying many small things and my friend from Boston sending me to Ireland and never I pay any penny.
    That's the airbag what I have. Steering wheel also but is without Multifunction
  31. #30
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,451
    if this item is for sale, please put it in classfieds. Thank you.
  1. 2010 Audi S4 vs 2007 Audi RS4
    By trev0006 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 22nd April 2010, 13:26
  2. airbag wiring harness s3 2007
    By djlazyp in forum Parts Requests
    Last Post: 25th March 2010, 22:45
