Monster MotorsportChris Nott
Results 1 to 13 of 13
    Feb 2013
    Cornwall
    81
    Rear washer not working
    I have a 56 plate 2.0 tdi 170, the rear washer doesn't work. You can hear the washer motor work but no water on the rear screen.
    Anyone suffered from this before? I'm guessing blocked pipe or a pipe off somewhere? But I can't find any wet patches inside the car.
    any help? Thanks
    Jan 2013
    159
    Its the washer jet. Search for threads as this was only discussed a couple of days ago.
    Need to remove the cover and washer jet then soak in vinegar for a day or 2 and wash properly
    27,114
    Search the forum, its been discussed a hell of allot.
    For the record, remove the black plastic jet push on part, on the rear wiper nipple by the glass & see if the water comes out then, if so then the jets are blocked, just use a needle to unblock, if not then could be the pipes come of, any water in the boot or on the boot lid trip bottom?
    Oct 2012
    492
    Just swaped mine today £6 on ebay
    Jan 2013
    159
    Feb 2013
    Cornwall
    81
    Can't see any water in the boot or boot lid. Will have a good look at the jets tomorrow then.
    audicruiser's Avatar
    Audi Heaven
    Somerset
    1,861
    Quote Originally Posted by tr1ck View Post
    Please search!! It's a common fault.... Will either be th pipe between the car and the tailgate, or th washer through the motor. The water will be going somewhere it shouldn't be!
    Scott
    Audi A3 Sportback 2.0T Quattro S-Line 2007 8P2
    Lava Grey, Exclusive Line Black/Silver Leather, Heated Seats, Bose, RNS-e, iPod, Auto Lights & Wipers, Interior Light Pack
    Stol1975's Avatar
    Sep 2012
    227
    Check it quick and sort the blockage out before you have a wet and faulty rear wiper motor cause then its an £80 repair.
    Feb 2013
    Cornwall
    81
    Had a quick check this morning. Took the jet off and worked the washer and the water shoots out! New jet it is
    27,114
    Just out a needle through it, will unblock it, saves the hassle of going to dealer.
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    As above.
    VCDS USER
    Feb 2013
    Cornwall
    81
    I saw someone mentioned soaking in vinegar. Giving that a go then will have a good clean out with a pin and try
    27,114
    No point with vinegar tbh, just use a needle, 1 minute later unblocked
  1. Rear window washer not working?
    By Jonezy87 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th July 2013, 15:26
  2. Rear Washer Not Working
    By 8385HJ in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th February 2012, 20:36
  3. Front and rear washer not working, but headlight washers are fine!
    By guinness in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2010, 19:20
  4. Rear washer not working
    By banoffee in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd November 2009, 14:18
  5. Back washer not working.....leaking hose in rear quarter???
    By Craigybaby37_A3quattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th January 2008, 19:36
