Volks AutosAH Fabrications
Results 1 to 7 of 7
    Jun 2012
    97
    What size spacers
    So I've got handr springs fitted and bilstein b8 shocks I've got some rep bbs ch alloys fitted with 225 40s the alloys are et 45 so what spacers can I have without rubbing also where do I get them and the bolts from thanks guys dan
    Feb 2009
    Aberdeen
    2,490
    Assuming 8" wide? If so, leave them without spacers.
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
    Jun 2012
    97
    Yh they are 8 inch wide what makes you say not to bother they sit in a lot thanks dan
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,210
    10mm front and 12mm rear should get them pretty flush, 8mm front and 10mm rear if you want a little more clearance.
    Damian @ DPM Performance
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    Jun 2012
    97
    And that's okay with then being et 45 offset ? How much is this going to cost me then also with correct bolts do I need to take in to counter that the oddest is Diffrent to standard so the bolts will need to be slightly longer on top of the spacer length if you understand thanks dan
    whale's Avatar
    Jul 2012
    Auckland, New Zealand
    55
    If nothing is rubbing, are there any advantages to adding spacers apart from aesthetics? i.e. Improved handling?
    Jun 2012
    97
    I was going more for looks tbh bringing the wheels out to the arches will make it look lower and look a lot better
  1. what size spacers
    By tdi-man in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th April 2012, 18:12
  2. What size spacers are best for S3 standard 17"wheels ?
    By S3 JOHN in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd December 2011, 16:51
  3. What size spacers to go for any idea ?
    By bigblokey0 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th December 2011, 10:03
  4. Hello! its my first post - What size spacer's should I get?
    By Dan76 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th August 2009, 15:39
  5. What size spacers for 19" rims??
    By amoani in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th December 2006, 14:41
