So I've got handr springs fitted and bilstein b8 shocks I've got some rep bbs ch alloys fitted with 225 40s the alloys are et 45 so what spacers can I have without rubbing also where do I get them and the bolts from thanks guys dan
And that's okay with then being et 45 offset ? How much is this going to cost me then also with correct bolts do I need to take in to counter that the oddest is Diffrent to standard so the bolts will need to be slightly longer on top of the spacer length if you understand thanks dan
