AH FabricationsChris Nott
Results 1 to 17 of 17
    Jan 2013
    159
    Why does my S3 have a bin in the boot full of water? Boot water leaked SOLVED
    Hi, from previous threads I have had a huge problem with water in my boot.
    Checking pipes and washer jet fixings did not suffice any hard evidence.
    So today I decided to remove the black metal cover from the the boot as pictured on the right of the boot
    Heres what we found
    Now nothing was connected to this box of water so how has it got there, what's it for, and I have now sealed it with silicone for future no leaking!
    I am intrigued to know what it is!!
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    In The Sticks....
    2,623
    On the A3 3.2, there wasnt enough room for the engine and battery up front,
    So they moved it to the back - its a battery box.
    As for water getting in there, could be a difficult one to find, but i'd suggest setting up a sprinkler system and stick the seats down and watch for leaks.
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    Aug 2012
    Aberdeen
    35
    Looks like a handy compartment for storing tools etc. Need to check mine. Do all 8Ps have this or is it just later models. I have a 2006 2.0 TDI
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,791
    That's where the WMI system on mine is installed.
    Very useful!
    RYes3's Avatar
    Apr 2012
    Cheshire
    730
    My battery lives in there!
    2012 RS3 Ibis White | Black Styling Pack | Black Roof Rails | Bose | Cruise | Tyre Package | Privacy Glass
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,162
    Perhaps deceptive in pics, but the compartment does not look large enough nor right shape for a battery to fit in there.
    Essentially the same quattro set up, why is it the battery in my 2009 non S3 Quattro, is mounted in the engine bay?
    shariain's Avatar
    May 2004
    Glasgow
    1,170
    My 2004 3.2v6 battery goes in there.
    S3 1.8t Ming blue with ivory leather & 18"tt alloys
    bmh.01's Avatar
    Apr 2012
    Nuneaton
    277
    The seal isn't very good between the boot floor and the box so they let water in, mine was doing the same thing cleaned it up and hoping it won't need silicone but i'll see.
    Quote Originally Posted by MrLapou View Post
    It's big enough for a battery. Read the thread only the 3.2 and RS3 have the batteries mounted there.
    Oct 2012
    Stoke-on-Trent
    85
    My 8p s line sportback I have noticed has a leak in the boot! Noticed the other day, haven't had time to look properly yet but the spare wheel bay was quite full with water. Seems to be some kind of leak on the left hand side as that's the only area that's wet.
    Any idea's on area's to look at?
    Jan 2013
    159
    You need to check for water in the headlinings and surrounding areas mate. Then we can advise! Do your water jets work?
    Oct 2012
    Stoke-on-Trent
    85
    Washer works fine. Take it to Audi they will rinse me. Im gonna have a proper look on my week off soon. Needs sorting
    Jan 2013
    159
    Do you have the box the same as mine as pictured then? The battery box? Can you hear water sloshing when driving? Put the seats down and take everything out boot till its bare metal and switch your stereo off and listen for water noise
    Oct 2012
    Stoke-on-Trent
    85
    Well that is what made me look hearing water splashing about in the boot, thought I was hearing things until I had a proper look. I'm not sure on layout as haven't properly looked.
    Oct 2012
    Stoke-on-Trent
    85
    I'm pretty sure there is no battery box like yours
    Jan 2013
    159
    Same problem as me!!
    The car will not leak if standing. The water only comes out when you go fast on corners etc and the water then gets through the cover.
    if you need any advice whilst looking at the car I am happy to help on the phone etc.
    drove me mad but mine is now resolved
    Jan 2013
    159
    Hmmm ok.... You can stick your head under the car and you will see one as well. For future reference, theres a small screw under the box that you need to remove to remove the battery box properly to clean and dry it
    Oct 2012
    Stoke-on-Trent
    85
    Now it's just a case of finding where the leak is coming from. But I may need give you a bell if I struggle finding a solution.
  1. Why does my SPORT not have OBC or Armrest? :Fuming:
    By BKZ187 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th January 2011, 08:27
  2. Why does the s line kit have no side skirts?
    By dappa786 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th July 2008, 00:27
  3. Why Does NO ONE have the 2008 A4?????
    By Defratos in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 22nd June 2008, 19:13
  4. Why does the Sportback have different rear lights?
    By mark88 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th June 2006, 01:28
  5. Why does this 5000 quit on its own??
    By Sabre60 in forum Classic Audi Forum
    Last Post: 5th May 2004, 01:40
