AH FabricationsJMB Retrofits
    Feb 2013
    11
    Exclamation ASV schematics/pinout
    Does anyone with ELSA access has the electrical diagram for the ASV valve?, the 4 pin one
    Also, what are the expected I/O signals?
    aaaand i know this is probably impossible, but the schematics for the control circuitry inside the ASV would be a plus
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,785
    Absolutely no idea what this is, but a man who is very technical on this forum is NHN.
    Private message him here ------> Send Private Message
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    Feb 2013
    11
    many thanks, i've found the wiring schematics ( Autotecnic2000.com )
    but i don't know HOW is it controlled, what kind of signal is sent to/from the ASV unit
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,785
    Quote Originally Posted by Eliminateur View Post
    Rather you than me with this!
    Good luck!
    A3 SportBack 2TFSI quattro DSG
    Jul 2009
    Norway
    226
    Pin 1 is -/ground
    Pin 2 is +/12v
    Pin 3 and 4 is analoug signal for directional and opening/closing level. Probably +/-5v regulating like a servo.
    Not 100% sure thou.
    What does this valve do?
    God luck
    Best regards
    J$B
    Norway
    Feb 2013
    11
    but which one of 3 and 4 is input and output?, both of them can't be inputs has a simple PWM input can be used to set the desired opening level in %
    the ASV it has 2 functions: antishudder on stop (and preventing a engine runaway as well if it's happening) and modulating the air intake ammount to optimize EGR "suction" (i.e.: closes the air intake so the engine sucks more EGR gases)
    engine is perfectly "functional" without it(other than the CEL light turning on and violent shudder on shutdown) and it's quite an expensive bugger so i want to fix it myself
  1. S3 Front Suspension Diagram/Schematic please
    By jonS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th January 2008, 16:57
  2. Pinouts for Audi Sub?
    By gizze in forum In-Car Entertainment
    Last Post: 16th September 2005, 20:37
  3. S3 Diagrams or schematics for Engine/transmission mounts?
    By imported_ashs3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st April 2005, 01:17
  4. Audi Bose Concert 13pin Connector Pinouts
    By Olly__K in forum In-Car Entertainment
    Last Post: 15th February 2005, 19:21
  5. ecu pinouts
    By blulude in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th December 2004, 20:55
