Sky InsuranceAH Fabrications
    Gryphon001's Avatar
    Jun 2009
    303
    Having some issues and could use a bit of help or some opinions at least...
    I'll settle for educated guesses at this point...
    Ok, I will try to give you a bit of background without boring you to death (key word being try)...
    I currently have 2008 A3 FSI with about 120,000km on the car.
    The car is stage 2+ I have a APR HPFP, APR 3" downpipe with Sport catback and APR stage 2+ software. Untill last year I still had a stock intake with just the Carbonio air box and the car ran fine. Last year I decided to upgrade to a Neuspeed P-flo intake.
    Soon as the intake went on, car would go into limp mode, loose power and no codes would show up. The car wouldn't show any fault codes but if I would clear the codes the car would run fine for a while, sometimes feeling even more powerful than before. APR made an educated guess that the most likely culprit was fuel trims maxing out but didn't have a solution aside from buying one of their VW Racing intakes and trying that.
    Stock intake went back on and the car ran fine. But I tried getting the VWRacing intake and the Forge Wintake for many months without success. Eventually ending up with a Forge Twintake.
    Installed it last night, car ran fine. Drove a bit today, car ran fine... went to my mechanic to replace the spark plugs this afternoon. My mechanic set them at a 7mm (0.0275) gap old plugs had about 60,000km on them and were totally toast but the gap on them had been what came out of the box which was about 9mm (0.035). When I went for a test drive the car felt down on power though.
    Took it back, checked for codes and nothing. Reset codes and the car ran like it's supposed to again. Looked like the mysterious limp mode came back again. Took the car for another test drive and the car started having serious backfire in 1st and 2nd gears and felt like it was over boosting a bit.
    Tried resetting the APR program from 93 to 91 and the car seemed to go back to normal, even ran fine when back into 93 octane program.
    But since than it has gone limp 3-4 times, the idle can't seem to settle down sometimes and twice the idle would get stuck at 2500rpm and only very slowly come back down to normal.
    Once again, no codes show on VCDS but when I reset them the car goes back to normal again for a while.
    Can anyone please help me and maybe shed some light on what the hell is going on?
    Thanks in advance for any useful feedback.
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    683
    It's difficult to advise remotely, but if i had the car I would start with a series of data logs. Have you had a look at what your fuel trims are? I am not familar with the intake you mention, but if the MAF housing area is any different from standard, you will run into problems.
    Rick
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
    Gryphon001's Avatar
    Jun 2009
    303
    This is what my engine bay looks like right now
    This is the intake I tried last year
    the MAF seems to be in the exact same spot as my OEM one was.
    I have VCDS, only got it a couple of weeks ago, but I'm still trying to figure out which parameters I should be logging though.
  1. Some log data - Could anyone have a nosey over it?
    By BlackQuat in forum VCDS (formerly VAG-COM) forum
    Last Post: 17th February 2011, 18:55
  2. Does anyone have a home pressurisation kit i could use?
    By audison in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th July 2010, 13:10
  3. A few issues I could use some help with.
    By eightrac in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th October 2009, 08:04
  4. Replies: 8
    Last Post: 16th June 2009, 19:38
