AH FabricationsVolks Autos
Results 1 to 8 of 8
    _G_
    _G_'s Avatar
    Jul 2011
    869
    Question Spot of mayonnaise under the oil cap...
    She's a thirsty girl, 2.0 TFSI 8p2 S-Tronic. Was topping up 1 quart of oil after 800 miles and noticed some white gunk under the oil cap rim...
    Half of it was covered at least but it was not too thick...
    Is this a head gasket job? How much would that cost? I think it is pre-warning signs anyway. The car runs fine. Does not over heat. Idles fine etc. I have been driving about 50 motorway miles a day (5 days a week) and need it for work!!
    No visible leaks on any coolant hoses.
    Any advice as to what it may be, if its a common problem and the damage to the wallet?
    Many Thanks!
    Boon's Avatar
    Sep 2012
    South East Kent
    428
    Depends on how much 'mayo' there is, and also the temperatures of both ambient & engine...
    Could quite simply be condensation
    chris.vincent3's Avatar
    Apr 2012
    UK, Portsmouth
    601
    Is it on the dipstick? If it is will probably be head gasket, if not will probably be condensation, however 50 motorway miles should clear it.
    audicruiser's Avatar
    Audi Heaven
    Somerset
    1,861
    Normal for this time of year with these engines. A good hard run (non motorway as the engine isn't working hard then) in the country will clear it.
    Scott
    Audi A3 Sportback 2.0T Quattro S-Line 2007 8P2
    Lava Grey, Exclusive Line Black/Silver Leather, Heated Seats, Bose, RNS-e, iPod, Auto Lights & Wipers, Interior Light Pack
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,924
    _G_
    _G_'s Avatar
    Jul 2011
    869
    cheers lads
    none on the dipstick and oil looks fine on the dip stick too i.e. not watery
    I cleaned it off... took it for a country road run and its all good so far.
    No coolant loss so hope it stays good.
    The Governor's Avatar
    Mar 2012
    Southampton
    436
    Not that I'm an oil officianado or anything, but I wonder if it would help putting a different oil in, like 5w20 as that will heat up more quickly...
    Audi Heaven
    Somerset
    1,861
    Quote Originally Posted by The Governor View Post
    No! Stick with what it recommended. Changing the oil weight will lead to other issues!
    Scott
  1. Yellow residue under oil cap
    By New2Audi in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th April 2012, 18:01
  2. Mayonaise on oil cap - diagnostic help please.
    By Rex16 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th March 2012, 20:49
  3. SMOKE FROM THE OIL CAP? 2.5 V6 Q 180
    By swarcup in forum Diesel forum
    Last Post: 19th March 2011, 20:33
  4. Oil Around The Filler Cap - PCV Valve / Filter
    By StagsyA4 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 8th August 2010, 01:47
  5. Guck under the oil filler cap
    By darrenp in forum Volkswagen and other VAG
    Last Post: 13th April 2006, 20:41
