Chris NottVolks Autos
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By blodderz
Thread: Key Fob Replacement
    Jan 2013
    61
    Key Fob Replacement
    Hello,
    I stood on my keys the other day and have broken the spring mechanism in the fob so basically my key just flops around & won't lock in place. Im going to buy a blank case and key off eBay and transfer the key and internals over, is it as straight forward as that?
    thanks,
    Andy
    Fossie
    Rhubarb Triangle
    3,969
    Provided you CAREFULLY move the immobiliser chip ( which is glass and glued in ) as well as the circuit board then yes, it's as straightforward as that !
    But be very careful !
    Jan 2013
    61
    Brilliant, thank you very much Mike!
    gussyldr's Avatar
    Oct 2010
    East London
    93
    be very very careful when takeing out the immobiliser chip i broke mine trying to pry it out
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by gussyldr View Post
    That's what I emphasised in my answer.
    Blodderz, bear in mind that if you do break it you could be looking at £150 - £200 to have it replaced !
    Jan 2013
    61
    Ill be extremely careful. My current keyfob is knackered, its battered to hell and like i said the key wont lock in place. Desperate for a new one.
    Whats the best way to open the case?
    Fossie
    Rhubarb Triangle
    3,969
    Blodderz mate, with the greatest respect, if you have to ask what is the best way to open the key fob then I really don't think you should be attempting a delicate operation like this !
    I presume you have the key fob with the chrome strip running down the right hand side and underneath? If so, then you will see a slot underneath which separates the two halves by the twist of a coin or screwdriver.
    You also need to be very careful not to lose the spring which flicks the key out. The tension of this spring can be altered to make the key operate better.
    Good luck !
    Jan 2013
    61
    Just thought I'd reply saying the transfer was successful. All done in 5-10mins, no broken immobiliser and everythings works perfect
    martinivw likes this.
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by blodderz View Post
    Nice one !!
    Jan 2013
    61
    Nice one !!
    Thanks for your help mike!
    Fossie
    Rhubarb Triangle
    3,969
    You're welcome - any time !
  1. Replacement key fob
    By Cabbyfan in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th February 2011, 20:35
  2. Battery Replacement - Key Fob
    By I'mRonBurgundy? in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th September 2010, 14:09
  3. Key Fob battery replaced and still doesnt work
    By beerglass in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 25th August 2010, 22:37
  4. Audi S3 Key Fob replacement/spare cost
    By W14FEN in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th September 2007, 18:48
  5. S3 Remote Key Fob Replacement
    By ash_s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th September 2006, 19:02
