Monster MotorsportEM Tuning
Results 1 to 11 of 11
    Feb 2013
    6
    'Woosh' Noise gone noisier when changing gear, (video)
    It's a 2.0L TDI, was fine earlier today and now suddenly just makes a massive woosh/owl noise when changing gears, and it the turbo noise seems to have gone at 2nd rev but sometimes the owl noise happens when you put the accelerator down.
    Also when starting up now it sounds like a 'crash' after its started up for a second
    chris.vincent3's Avatar
    Apr 2012
    UK, Portsmouth
    568
    How is the car running? It's just the diverter valve going off when you change gear realeasing pressure that the turbo has spooled up. It's normal to a certain extent where it has been know for a turbo to be on its way out, however from your description it's fine and the car isn't running with any dramas or fault codes.
    May 2012
    York
    204
    sounds normal to me
    Feb 2013
    6
    Quote Originally Posted by chris.vincent3 View Post
    Even if its gone alot noisier since last night? And when i start the car the engine suddenly seems to 'drop' after startup, hard to explain
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    933
    No diverter valve on a diesel.
    VCDS USER
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,572
    Hole in backbox?
    Audi A3 2.0TFSI S Line SE DSG
    JMB Retrofits - North East Retrofit Company
    Feb 2013
    6
    I just took it to a local garage and he wouldnt con me i dont think, dads friend.
    He asked me to rev it he checked under the bonnet and in engine and he said there was a leak, then said the turbo pipe was cracked, and needs a new one, which would cost around £100 ?
    15 February 2013 04:52 | Facebook
    Feb 2013
    6
    Feb 2013
    6
    Quote Originally Posted by nathwoz89 View Post
    Any feedback from what the guy said and the video?
    Feb 2011
    Plymouth
    940
    getting instantly louder could well be a cracked pipe, or hole on exhaust near the turbo. get it smoke tested to see if its leaking but i wouldnt worry about it tbh
    Feb 2013
    6
    It was something to do with the intercooling pipe after all... strange
  1. Clunking noise when changing gear
    By Brendan12 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st May 2011, 09:53
  2. Clunking Noise When Changing Gears
    By JUX in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th May 2008, 21:53
  3. stalling when changing gears on S3
    By froggy72 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th December 2006, 15:04
  4. continues to rev when changing gear?
    By jaysback in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th April 2006, 20:29
  5. Over Revving when changing gear - Fixed!
    By h3msy in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th April 2005, 13:21
