Volks AutosMonster Motorsport
Results 1 to 21 of 21
    Nov 2012
    47
    Clutch pedal sticking down!!!!
    Hi my clutch on my audi a3 sportback 2007 plate is sticking quite often now and it's hard to put it into and out of the gears.. Can anyone point me in the right direction as to where the fault is? I've read about clutch master cylinder or the clutch bracket being reasons for this. Can anyone help me out and point me in the right direction? Il be very appreciated..
    Boon's Avatar
    Sep 2012
    South East Kent
    346
    Have you had the brake/clutch fluid changed and bleed lately?
    I'd get it checked & changed first before any major components
    Jun 2011
    Great Melton Norfolk
    1,340
    Slave is quite common, but its in the gearbox, how many miles has the car done?
    Nov 2012
    47
    Quote Originally Posted by Boon View Post
    Hi not had the brake fluid changed but was advised on audi health check. Shall I get this done and can this be the cause?
    Nov 2012
    47
    Car has done 125k miles and with full audi history.
    Boon's Avatar
    Sep 2012
    South East Kent
    346
    Quote Originally Posted by dawudbhai View Post
    Yes it can be a symptom, as can the slave cylinder & as said this is in the gearbox (hours of labour just to get to it to change)
    Fluid change is much cheaper and should be done every few years anyway as it absorbs moisture & starts to compress. Not to mention safety issues with braking.
    They can be a pain to bleed the clutches though... Not with a pressure/suction fluid change system...
    That would be my first point of call
    Nov 2012
    47
    so my best bet is to change the brake fluid? and then get the clutch bled? roughly how much would it cost to bleed and change the fluid? also, how much is labour cost to change the cylinder? or can this be my clutch on its way out. it does judder on idle but thats probably the dmf??? any ideas
    Boon's Avatar
    Sep 2012
    South East Kent
    346
    Yes I should have also said that at that mileage it could well be the clutch at the end of its life, juddering could well be the duel mass flywheel...
    Was simply asking if you had changed the fluid as this often gets overlooked...
    Changing the clutch or even just the slave cylinder is fairly major job... Lots of parts need to be removed... Most places will quote a time scale of around 6 to 8 hours plus the cost of the clutch, you'd really need to get quotes from your local dealer/garages.
    Have heard figures from around £800-£1200!!! I got mine done at cost parts because I have a fantastic mechanic (around £400)
    Mar 2010
    Cleveland, North East
    200
    Try bleeding it first as said.
    There is a clutch delay valve in the pipe between the master and slave cylinder. These have a habit of breaking in cold weather conditions giving the symptoms you describe, quite often overlooked.
    Dec 2011
    MIDLANDS
    241
    i had this on my leon cupra r. It turned out to be the slave cylinder which was also inside the gearbox. i opted which would probably be wise for your mileage car, to change the clutch aswell at the same time. that is if you decide to go down that route.
    A3 2.0TDI S LINE, Awesome remapped, ITG, Milltek, S3 Front + Rear bumpers + Sideskirts, Cruise and slammed on coilovers. NO SMOKE - NO POKE!!!!!
    Nov 2012
    47
    Quote Originally Posted by WALTO TDI View Post
    Hi where is this delay valve? Any pics or guides as to find it.. If it is a major job, ie clutch change etc roughly how much would it cost for everything?
    Dec 2011
    MIDLANDS
    241
    not too sure on the audi but for the leon it cost me £400 from a local vw audi approved specialist
    Nov 2012
    47
    Did you change clutch and flywheel inc labour?
    Dec 2011
    MIDLANDS
    241
    no didnt touch the flywheel, just clutch, slave and master cylinder and labour costs.
    Nov 2012
    47
    Ok but isn't it recommended to change flywheel too?
    Dec 2011
    MIDLANDS
    241
    not unless you have a problem with it
    Nov 2012
    47
    Ok I checked my brake fluid and it was a little low off the max line.. I've topped it up and it seems to start working again just want to know where have I lost some of the fluid? Can't see anything external or under the car. Probably internal? All help will be appreciated
    jaydav2306's Avatar
    Had this on my TT, you can delay it all you want but somewhere in the next 10k miles you'll be needing clutch, slsve and master cylinder
    2009/2010 | Audi S3 Black Edition Ibis White | Black Optics Pack | Fully Loaded | S-Tronic
    jaydav2306's Avatar
    You will be leaking it from the slave most probably onto the clutch
    Nov 2012
    47
    The master cylinder which is located under the clutch pedal is dry. Isn't the slave cylinder in gearbox? The car is on it's first clutch so will prob need doing soon. Will I have to top up the fluid now as well? I don't do many miles so 10k is alot of miles..
    jaydav2306's Avatar
    Just because it's dry dosent mean its not on its way out, would still be worth getting someone to have a look at it, normally brake and clutch share same reservoir so I wouldnt mess about
  1. Clutch pedal sticking down!
    By 9-Points&Counting in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd February 2011, 09:29
  2. S3 clutch pedal sticking down. Help!!!!
    By forty3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd December 2010, 21:37
  3. Clutch pedal stuck down,not broken peddle
    By Broken Byzan in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th December 2008, 15:25
  4. Clutch pedal went down and dicided to stay there!!!
    By Jonesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th November 2008, 18:55
  5. Clutch pedal sticking
    By monty77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd February 2005, 14:58
