AH FabricationsEM Tuning
    Oct 2004
    9
    Rear Light Removal
    Hi guys need to remove one of rear lights, doesn't seem aligned properly and was wondering if its easy todo?
    Drew
    Eeef's Avatar
    Lord of War
    Nov 2004
    South Coast, land of the white man
    1,602
    Re: Rear Light Removal
    3dr or sportback? What year?
    Oct 2004
    9
    yea that might help :-)
    3 Door 54 Plate.
    Hi DrewA3 - instructions and illustrations from Elsawin
    illustration - A94-0632
    1 - Retaining pin - screwed into housing
    2 - Clip nut
    3 - Electrical connector
    4 - Cap nut - 3.5 Nm
    5 - O-ring
    6 - Stud - 3.5 Nm
    7 - Bulb for brake light - 12 V, 21 W
    8 - Tail light bulb - 12 V, 10 W
    9 - Bulb -12 V, 21 W - Driver's side: For fog tail light - Passenger side: For reversing light
    10 - Housing
    11 - Turn signal bulb - 12 V, 21 W - Amber colour
    12 - Bulb carrier
    Removing
    Switch off ignition and remove ignition key.
    Turn light switch to 0 position.
    Unclip plug -2- from luggage compartment lining.
    Unscrew cap nut -1-.
    Swivel rear light out slightly on inside -arrow 1-.
    Turn rear light slightly -arrow 2- on outside to withdraw from clip nuts.
    Unplug connector at bulb carrier.
    Press apart catches -arrows- and take bulb carrier out of rear light.
    Screw bulbs out of bulb holders.
    illustration - A94-0633
    illustration - A94-0603
    Installing
    Install in reverse order, paying attention to the following:
    Note! - Ensure tight seal between body and rear light housing.
    Oct 2004
    9
    Wow Cheers David much appreciated :-)
