AH FabricationsEM Tuning
    Feb 2013
    LONG CODING CCS, S3 8P Please can someone help :)
    Hi there.
    I have just fitted the retrofit ccs to an S3 08 plate. I've managed to get code 000022 accepted in steering systems but the engine coding requires the long code. This is a code we do not have and could really do with some help on this please.
    Can someone come back to us or recommend?
    Fossie
    Rhubarb Triangle
    3,969
    My 2006 needed 11463 in engine module coding 11
    See if this helps :- Checking Cruise Control using Measuring Values - Ross-Tech Wiki
    it's not Audi A3 but Golf 5/6 so should be similar.
    Feb 2013
    Hi Mike. We're all sorted now thankyou, We had the code already -we thought it was incorrect as it wouldn't activate. As it turns out it was right but there was just a minor process (a 30 second wait) we had overlooked - all activated now and ready to roll
    Thanks for your speedy reply and to Dan, who educated us on the delay
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by FVSIOM View Post
    You're welcome - glad you got it sorted !
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    Glad I could help out and you got it all sorted. I will be holding Si to that pint if ever I am in the Isle of Man :-)
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
  1. Cruise Control - Please can someone check the coding I've found is correct
    By danb986 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd September 2011, 08:58
  2. Gearbox? Driveshaft ? noise can someone help please ?
    By dentsy in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 20th February 2011, 10:57
  3. Please please can someone tell me.....
    By slinx in forum TT/TT-S/TT-RS Forum
    Last Post: 15th August 2007, 14:04
  4. can someone help me out with a part number please
    By imported_kris_tdi in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th February 2006, 20:22
  5. Can someone help me please
    By imported_ANNANBHOY in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th September 2005, 14:16
