JMB RetrofitsBadger5
    Beagles's Avatar
    Apr 2012
    Cornwall
    88
    Audi A3 2.- TDi clutch options
    hi guys,
    sorry about this, i know there are hundreds of pages on this, and believe me i've read them all! Still i have no clue what to do as mine has started to shudder and gear selection is becoming harder and harder(holding people up at the lights is not fun because i refuse to ram my gearbox).
    Basically i pretty much think my clutch and DMF is shod! it shudders and the clutch isn't fully disengaging and gear selection is a pain in the backside! but there's so many choices and i don't have a clue where to start..
    1) do i convert to single mass flywheel?
    2) just replace with standard Oem sach clutch and dual mass flywheel?
    3) upgrade to the sachs organic and flywheel?
    4) or any other upgraded clutch/flywhee;
    Dont really wanna be replacing it again too soon, especially after the remap!
    My car is currently standard engine wise, but i was going to remap it next week which is now put off to do the clutch first! The guys where its being done(R K Engineering) say there hopeful for about 185BHP which they;ve seen come out of these before and which ill be chuffed with as mines a 140. and also dont plan on doing any other power mods after the remap i would of thought either!
    sorry about the repeat thread, just could never make a decision and i need to pretty sharpish!
    Any help much appreciated!
    Beagles
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,217
    tbh just stick to oem if you're going to add is a remap.
    Beagles's Avatar
    Apr 2012
    Cornwall
    88
    Thanks for the reply sliced... Hmmm really? It is alot cheaper than a upgraded.... Also wondering if changing the clutch will also solve the struggle getting it into gear... Some people blame it on the cold too. Think ill check the slack in the gear linkages and adjust tomorrow and see if it makes any difference!
    27,099
    1st of all forget the remap until you fix the issues as it could make it allow worse & stick with oem tbh on a generic map, it will be fine.
    Jun 2011
    138
    Quote Originally Posted by Beagles View Post
    changing gear box oil will help getting in and out of gear, get some here VW Audi Gear Box Oil 1litre for Manual Transmissions - FR&R Tuning| MAHA Dyno Rolling Road Tuning| Stage 1, 2 & 3 Engine Performance Upgrades - (Powered by CubeCart)
    Audi S3 2.0TFSI.. Milltek Turbo-Back Non-Res, ITG maxogen, THS FMIC, HPFP internals, Custom FR&RTuning dyno Software
    Previous
    Audi S3 1.8T with the following mods: Milltek Cat Back Non Res exhaust, with THS Decat, Induction kit , Forge 007P Valve and Custom FR-RTuning Stage 2 Software..
  1. Audi 1.9 TDI - Clutch
    By amz in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th November 2012, 14:19
  2. Audi A4 B6 TDI Clutch Going... On Its Way Out Engine AWX
    By samsam in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th October 2011, 21:52
  3. Audi A3 tdi ~ clutch & flywheel knackered! :(
    By 337lee in forum General Technical / How To
    Last Post: 20th August 2007, 14:40
  4. Audi A3 tdi ~ clutch & flywheel knackered! :(
    By 337lee in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th July 2007, 20:11
  5. Audi A3 tdi ~ clutch & flywheel knackered! :(
    By 337lee in forum Diesel forum
    Last Post: 18th July 2007, 16:53
