AH FabricationsSky Insurance
Results 1 to 20 of 20
Like Tree2Likes
  • 2 Post By S3Alex
Thread: S3 8PA - stage 2 - mods questions
    Aug 2012
    13
    Hi Guys,
    I'm planning to run Stage 2 on my S3 8PA sportback. From my local tunner i was told to get around 350-370BHP (depenging on engine performance) but i need following things to do:
    a) new air system: Cold Air Induction or... Audi TTS air induction
    b) complete exhaust system
    c) CPU remap
    as my engine is CDLA i dont need autotech fuel injection system and mine is sufficent for 370BHP
    My car is running currently 280BHP on 98octan fuel bone stock, no single modification done.
    All is fine besides Audi TTS air induction which requires to move out the battery from front to trunk. Here comes my question: is there any other CAI i could use instead of AUdi TTS? I dont want to use FORGE CAI, as its expensive and hard in maintenance.
    I'd highly appreciate your suggestions !!
    Also i'm wondering if anyone has checked fuel consuption before / after Stage 2? Big di
    thanks & cheers
    mario
    PS: Any other mods should i consider while getting stage 2?
    Sep 2012
    Brum
    299
    You won't get that sort of gains and you will defiantly need to upgrade fuel pump ,full exhaust decent cai but upgrade brakes first. Safety first. I've done all of these and more and got 367 bhp.
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,773
    My car:
    Revo 2+ map
    RS4 Fuel regulator
    Autotech HPFP
    Revo Intake
    Revo/Eurojet FMIC
    Milltek TBE
    Forge Black DV
    Sach Organic Clutch
    348.2bhp (with ITG intake and 97ron fuel)
    Aug 2012
    13
    well i would not stick to numbers and say that 370 my tunner claims is real 370, as each dyno produces different numbers and your 340-360 might be 370-380bhp on dyno here.
    I have an issue with CAI as our roads are quite dirty with sand / small tiny rocks that can easily damage turbo and gets dirty very fast. I was told to go with audi TTS air intake, but it requires removing battery to trunk. If you don't know any other CAI / intake system don't do not require removing battery i guess i will go with TTS one.
    Why do i need new fuel pump? mine is 2009 model which has better efficiency than previous 04-08 - at least that's what i was told by two tunners i talked to here locally.
    My brakes doing well, but will replace them for Brembo once they get torn off. Discs + pads are enough or you suggest to get new calippers as well?
    many thanks for help
    Dec 2011
    226
    You will need hpfp are you sure they didn't say that your dv is ok as you've go the later version one ?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,791
    You should definitely have the brakes and suspension done,as otherwise you get something which is pretty good in a straight line,and very wobbly around bends.
    For anything in the 360-380bhp range(and 380bhp from the stock turbo is unlikely)you would need the HPFP upgrade for sure,and the new AMDTuning CAI,the ITG/VWracing filter,and the Neuspeed will all fit without moving the battery.
    Ben2487's Avatar
    Nov 2012
    73
    Quote Originally Posted by S3Alex View Post
    Don't forget Revo induction kit lol
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,791
    Quote Originally Posted by Ben2487 View Post
    Thanks...I knew there was something I'd missed...you know when you type or say something and you know you've forgotten something....
    Ben2487's Avatar
    Nov 2012
    73
    Yea lol, Quote lee evans " when you go out for a trip and your mind keeps telling you forgot something, you forgot something all the way there, than as you arrive it goes your wallet!"
    poli84's Avatar
    Nov 2010
    Melbourne. Australia
    430
    Quote Originally Posted by MarioS3 View Post
    The tuners you are speaking to are mistaking your TFSI engine for the 2.0TSI engine used in the newer 2.0T (and Golf GTI).
    The new 2.0TSI engines do not need the HPFP upgrade but the motor in the S3 still uses the old TFSI engine which requires the HPFP.
    I'd be double checking what your tuners say in the future as this is a pretty simple mistake which does not give them much credibility.
    Also, I would not be bothering with a TTS CAI and relocating your battery.
    Plenty of sealed units on the market which offer much better performance than a stock TTS unit.
    MY10 S3 Sportback - 6Sp Manual - Sprint Blue
    REVO Stage 2+ /
    Forge Twintake / 3" Miltek Hybrid DP/​ Autotech HPFP
    Bilstein PSS10
    / H&R 10/12mm Spacers / BFI Dog Bone /EBC Yellowstuff
    BUILD THREAD
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,791
    I know where my wallet is...under the bonnet of my car...LOL
    Aug 2012
    13
    Hi Guys,
    Thank you so much for your advices. My thoughts to go with TTS air induction was to secure turbo from derbies / small rocks / dirt that can get through the CAI – from what I heard? Do you know any workarounds / solutions to prevent turbo damage when installing CAI??
    HPFP is there just Autotech or any other you can recommend also?
    Sorry for lack of knowledge, but I don’t know what is “DV” and what is used for?
    I’ll google for Revo induction kit and check what it is.
    Thanks for help!
    cheers
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,332
    Hi Guys,
    Thanks for help!
    cheers
    I wouldnt worry about the turbo mate. Camfollower failure on Autotech pumps is much more common if not enough care is put in checking it every 5k/10k miles. Dont know how many turbos are gone bust but I havent heard of anyone yet on this forum.
    Be patient. English is tough.
    Now:
    61 Audi S3 BE S-Tronic Ibis White: Build Thread.
    / Black Edition pack (SatNav, Bluetooth) / Parking Sensors / Tinted windows / piano inlays and finish / Cruise Control / Interior light pack /
    /Mods: REVO Stage 2+: Revo Intake / Milltek Resonated TBE / LOBA HPFP/ GFB DV+ / Crystal Clear H11 FOGS / Black roof + spoiler vinyl wrap / H&R Anti-roll bars / Superpro ALK /
    Ben2487's Avatar
    Nov 2012
    73
    Quote Originally Posted by RedDejavu View Post
    Do you check the follower only when stage 2 or is it worth checking anyway just gone stage 1 with 35000 miles when would it be worth checking 40000??
    Black S3,
    Blue
    fin Stage 1,
    Revo induction kit,
    Forge Dv Kit,
    TTS Engine cover.
    Take a look
    Aug 2012
    13
    Any other HPFP than Autotech can you recommend for me? I'm not going further than stage 2 and i will stop on around 350BHP.
    thanks!
    mephisto's Avatar
    Oct 2004
    190
    Id like to jump in here, see some people mention the standard S3 Exhaust system is ok for 2/2+? And the downpipe is the restriction? Im looking at 2+ and of course fear the standard clutch. Wanted to spend it on clutch over exhaust/downpipe short term. Any figures approximations on using standard over modified for 2+?
    2009 S3 8P Phantom Black
    MODS : S3 Keyring
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,332
    only if you use Autotech HPFP or any uprated pump
    Now:
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,332
    thanks!
    LOBA does some great HPFP that dont fail very often actually none of them has yet from what I recall which is a good news and personally i would go ahead with it but costs around 700 mark and still camfollower check ups every 10k just for peace of mind would be required.
    Now:
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,332
    IF you stage 2 only you could have got it checked every service really or every 15k. Sorry for multiposting....
    Now:
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,791
    Any other HPFP than Autotech can you recommend for me? I'm not going further than stage 2 and i will stop on around 350BHP.thanks!
    Other than the Autotech(which is a pumps internals upgrade) you have the APR and Loba pumps.
    It should be said that with proper attention to cam follower maintenance,ALL of these pumps are reliable,and the Autotech will flow sufficient fuel for well over 500bhp.
  1. B7 acquired, modding questions....
    By The_Golfather in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 19th August 2009, 22:23
  2. Mk1 180bhp Roadster Remap / Mods Question
    By Stevie C in forum TT/TT-S/TT-RS Forum
    Last Post: 22nd February 2009, 19:55
  3. Dv and other mods Question
    By mattypgolf in forum Diesel forum
    Last Post: 22nd December 2008, 15:27
  4. couple of mod questions
    By AUDI TURBO in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd June 2008, 16:07
  5. ARB's and suspension mod questions!
    By stevieyid in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2008, 21:44
