My battery is draining over night it's a brand new battery and when I remove fuse 17 under the bonnet the drain stops does anybody no what this controls thanks
I did ask for an engine & box code, but alas, it depends on which electronics box is fitted, whether high or low, low shows the horns on F17 & high shows J285 dash panel insert, basically as above, cluster.
