Volks AutosSky Insurance
Results 1 to 7 of 7
    Feb 2013
    23
    Anyone got an OBD adapter on their 2003 A3 2.0 TDI?
    As the title says, just wondering if anyone has an OBD adapter on their 2003 A3 2.0 TDI.
    I'm buying my first Audi this week, and I'm just wondering what kind of stats I'd be likely to see in Torque-Pro?
    Anyone got any insights or advice on it? I've never used or done anything with OBD before, but it looks interesting.
    Will probably buy one of the ELM327 adapters on ebay.
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,209
    I do its pretty interesting but the novelty wears off after about a week. did a few 0-60's that it measured!
    Feb 2013
    23
    Quote Originally Posted by sliced View Post
    What other stats does it show you? I've read they vary from car to car depending on the sensors available, the newer the car the more info.
    Does this car have much else to say about itself other than 0-60 or is it pretty basic?
    sliced's Avatar
    Jun 2012
    1,209
    erm it tells you how fast you are going, what the o2 reading is. its pretty useless imo. Only one good thing is you can gps record the exact route you took
    Feb 2013
    23
    ok no problem, cheers Might need to reconsider buying it, I got the feeling I'd see more info than that, but like you say, sounds like a novelty that would end up never getting used.
    Thanks for the insight
    Jun 2011
    Great Melton Norfolk
    1,349
    Best off buying vcds , at least it is useful and you can measure your 0-60 as well.
    Feb 2013
    23
    Quote Originally Posted by gen.heinz guderian View Post
    Just did a quick search and found most of the VCDS stuff is really expensive, although there is a 'dumb' cable option which can be used with the shareware lite software from ross-tech.
    The ELM327 option was appealing because it was so cheap and also I could use it with my android phone, is VCDS for Windows only?
    What kind of stats would I be likely to get with that? (EDIT: On this particular car, not VCDS in general
  1. Has anyone got a firm date for their ordered RS3??
    By audicruiser in forum RS3 Forum
    Last Post: 9th July 2012, 17:32
  2. Anyone got these B7 alloys on their B6 Avant?
    By DALE_AVANT in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th April 2012, 15:46
  3. Anyone here got Custom Code map on their Diesel?
    By Mikey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th September 2008, 14:41
  4. Anyone got a factory-fitted Genuine towbar on their B5 A4?
    By Nessy in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd September 2006, 00:59
  5. Anyone got 18" BBS RSII's on their car?
    By 18ME in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th December 2003, 16:15
Tags for this Thread
