Chris NottVolks Autos
    Feb 2013
    Need help with vcds
    Can anybody help with this scan I've fixed the brake pressure sensor just the control module thanks
    Friday,01,February,2013,17:44:32:19586
    VCDS Version: Release 11.11.5
    Data version: 20121222
    Chassis Type: 1K0
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 56 7D
    VIN: WAUZZZ8P34A135604 Mileage: 167900km/104328miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: Malfunction 1010
    03-ABS Brakes -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 1010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: Malfunction 1010
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 1010
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: Malfunction 1010
    52-Door Elect, Pass. -- Status: Malfunction 1010
    56-Radio -- Status: Malfunction 1010
    7D-Aux. Heat -- Status: Sporadic communication error 1000
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 AT HW: 028 101 145 3
    Component: R4 2,0L EDC G200AG 5689
    Revision: 12345678 Serial number: AUX7Z0D1FN90B3
    Coding: 0000078
    Shop #: WSC 00359 210 53633
    VCID: 75EBCCF91C8DB4B002A
    No fault code found.
    Readiness: 0 0 1 1 1
    Address 02: Auto Trans Labels: 02E-300-0xx.lbl
    Part No SW: 02E 300 041 C HW: 02E 927 770 AD
    Component: GSG DSG 0623
    Revision: 04202624 Serial number: 00001002250639
    Coding: 0000020
    Shop #: WSC 06314 210 01865
    VCID: 122197650D230388878
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0103
    Coding: 0023174
    Shop #: WSC 06435 000 00000
    VCID: 3A711FC575131BC82F8
    1 Fault Found:
    01435 - Brake Pressure Sensor 1 (G201)
    012 - Electrical Fault in Circuit
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 D HW: 8P0 820 043 D
    Component: KlimavollautomatH12 0150
    Revision: 031759 Serial number: 8P0820043D
    Shop #: WSC 00000 000 00000
    VCID: 2D5B2499B45DBC70BAA
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 D HW: 8P0 907 279 D*
    Component: Bordnetz-SG 1.0 H28 0601
    Revision: 00028000 Serial number: 00000000483290
    Coding: A4885F00A2141000000000000000000000
    VCID: 3E7913D5693B37E8130
    Subsystem 1 - Part No: 8P2 955 119 C Labels: 1TX-955-119.CLB
    Component: Wischer WWS Audi350 0180
    Coding: 16711696
    Shop #: WSC 00000
    Address 15: Airbags Labels: 8P0-959-655-84.lbl
    Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
    Component: Airbag 8.4ED H00 0140
    Coding: 0011602
    VCID: 438F622102D95A007CE
    Address 16: Steering wheel Labels: 8P0-953-549.lbl
    Part No SW: 8P0 953 549 HW: 8P0 953 549
    Component: Lenksäulenmodul H11 0020
    Coding: 0011122
    VCID: FBFF5AC1BAA962C0F4E
    Part No: XXXXXXXXXXX
    Component: Lenkradmodul H02 0030
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 980 H HW: 8P0 920 980 H
    Component: KOMBIINSTR. VDO H25 0140
    Revision: D09 Serial number: 2241DD09003954
    Coding: 0002403
    Shop #: WSC 00581 067 57207
    VCID: 3C7D19DD7F2725F83D4
    1 Fault Found:
    00003 - Control Module
    014 - Defective
    Freeze Frame:
    Fault Status: 00000011
    Fault Priority: 1
    Fault Frequency: 1
    Mileage: 81205 km
    Time Indication: 0
    Date: 2008.08.22
    Time: 09:05:53
    Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
    Part No SW: 1K0 907 530 D HW: 1K0 907 951
    Component: Gateway H08 0100
    Revision: 08 Serial number: 2500104113003A
    Coding: 3F0F0B42070101
    VCID: 2855D58D9BBF995849C
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D09 Serial number: AUX7Z0D1FN90B3
    Shop #: WSC 00763 210 80270
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
    Part No: 8P0 959 801 A
    Component: Tuersteuerger. H10 0010
    Coding: 0000120
    VCID: 397300C9701510D0262
    1 Fault Found:
    00932 - Electric Window Motor; Drivers Side (V147)
    005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 E
    Component: EPS_ZFLS Kl.10 1202
    VCID: 2E592395B95BC768830
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433
    Component: KSG H02 0040
    Coding: 008800186D288505485AC63000
    VCID: F9F340C9B09550D0E62
    Part No: 1K0 951 605 A
    Component: LIN BACKUP HORN H01 1201
    Part No: 1K0 907 719
    Component: Neigungssensor 003 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H03 0010
    1 Fault Found:
    01299 - Diagnostic Interface for Data Bus (J533)
    013 - Check DTC Memory
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P3 035 382 HW: 8P3 035 382
    Component: AB2 SUBWOOFERBOXH23 0100
    Revision: 00001 Serial number: 10000001075899
    VCID: F0E57DEDE3EF119851C
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
    Part No: 8P0 959 802 A
    Coding: 0000120
    Address 56: Radio Labels: 8P0-035-1xx-56.lbl
    Part No SW: 8P0 035 186 HW: 8P0 035 186
    Component: concert II EU H53 0060
    Revision: 07S Serial number: AUZ2Z3D1846317
    Coding: 0001001
    VCID: EFE77E91FED10E60486
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 D HW: 1K0 963 235 D
    Component: PTC-Element 0404
    Revision: 00700000 Serial number:
    VCID: 2C5D299D8F47B578AD4
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Never seen so many "Status: Malfunction 0010" from one scan...
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,856
    Quote Originally Posted by MrLapou View Post
    The good news is his Steering Angle Sensor & Immobiliser are Okay!
    Seriously though, you probably need to clear all faults and rescan so others can see what's what.
    2009 A3 SB 2.0T DSG S line
    Feb 2013
    They have been cleared all that is left is the control module
    monopole's Avatar
    limboitis
    Oct 2012
    County Antrim
    313
    go into Module 17 and clear it from there, scan again.
    Infact, do all your modules one by one, select Fault Codes - 02, then Clear codes - 05 and that should clear the first bit too.
    +incoming MY15 S3 (300) Sportback S-Tronic Quattro Daytona Grey
    -outgoing (63) A5 2.0TDI (177) Coupe Black Edition S-Tronic Quattro Phantom Black
    VCDS Location: NI (County Antrim)
    - (62) A1 1.6TDI (105) Sport Manual Sportback Brilliant Black
    - (62) S3 (265) Sportback Black Edition S-Tronic Quattro Phantom Black
    - (58) TT Roadster 3.2 V6 (250) S-Tronic Quattro Phantom Black
    27,099
    Window just needs the one touch system setting, by using the window switch to drop window fully whilst holding button & an additional 10 seconds when fully open & release, then close using the same process.
    The cluster saying defective doesnt look good, as above stated, module 17, got into fault codes, click clear codes, cycle ignition, start car & test again & post results.
  1. Need help with power tool
    By Defratos in forum General Chat
    Last Post: 15th January 2007, 17:37
  2. Need help with latest interior mod!
    By silver75 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th August 2006, 11:59
  3. Need help with buying A4
    By samku in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd October 2004, 13:15
  4. Engine swap - need help with codes
    By Pincher in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th August 2004, 22:33
  5. Please I need help with spacers!!!
    By nianmuzik in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th April 2003, 22:44
