Chris NottAH Fabrications
    Nov 2011
    6
    N\S Power steering shacking a3 2.0tdi 06
    Hi all
    My Car has been shacking when accelerating and braking. i changed my discs a few months back.
    I noticed it looked like the power steering had play on the passenger side but fine on the drivers side.
    so i replaced the track rod but whilst doing it i saw the main shaft inside the rack had play and the track rod was fine. i replaced the rod anyway as i had it but the shack is still there, so looks like it is the steering rack. the rack doesn't creak and the steering is still good, but the car wobbles around :/
    I just want to know has anyone else had this issue? do i need to replace the whole rack and why would it only be on one side :S
    27,114
    If its got play inside the rack, then chances are its a replacement rack needed.
    Nov 2011
    6
    Dam cheers
  1. Power Steering Fluid
    By TrueNilbog in forum TT/TT-S/TT-RS Forum
    Last Post: 3rd October 2004, 02:24
  2. Power Steering Fluid Leaking A4 2.8 1997
    By bradmcw in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th March 2004, 12:53
  3. Noisy power steering?
    By GeorgieMcC in forum A8/S8 forum
    Last Post: 18th February 2004, 12:29
  4. V6 power steering
    By audiA3V6 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th February 2004, 18:34
  5. Power Steering Fluid
    By blued in forum General Technical / How To
    Last Post: 28th August 2003, 13:23
