JMB RetrofitsEM Tuning
Results 1 to 8 of 8
    DCW87's Avatar
    Feb 2012
    Northwich
    36
    2.0tdi 140 Loss of power after gear change?? any ideas?
    Hey guys,
    Looking for a bit of advice on an issue im having with my A3. Car starts fine, no issues, but when i set off and change up in gears there's a noticeable drop in power immediately after changing... Most noticeable between 2nd and 3rd and 3rd and 4th. The car never used to be like this and it only started happening after i put some deisel fuel treatment in the engine the last time i filled up...
    The best way to describe it is that the car seems to struggle to adjust to the new gear for 1/2 to 1 seconds before resuming acceleration as usual.
    any ideas on what this might be? Already spent 2.5k extra ont his car since i bought it 11 months ago and I'm dreading this being the start of yet another wallet burning crusade through the audi garage.
    Thanks in advance!
    DC
    beachbuggy's Avatar
    Surrey
    1,746
    Wrong forum.. You need the 8p one..
    DCW87's Avatar
    Feb 2012
    Northwich
    36
    sorry man! ermm... can i move this or do i need to rewrite it??
    DC
    beachbuggy's Avatar
    Surrey
    1,746
    Sure someone will move it for you.
    sounds like you have sticking vnt vanes though, which struggle to adjust during gear change.. Google sticking vnt .. Common problem on TDIs
    DCW87's Avatar
    Feb 2012
    Northwich
    36
    Thanks man, definitely looks like something similar to what im experiencing although im getting no error codes thrown at me?
    No im no mechanic, and i can just about change a tyre.... this looks like something which isnt particularly easy to fix....
    Am i looking at yet another hefty bill? :S
    DC
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    I've been having the same problem for a while now. Replaced MAF, fuel filter (bit of improvement after changing the latter). There are no overboost codes, car does not go into limp mode which I thought it would with sticking turbo vanes.
    Same engine as yours, turbo was replaced 20k miles ago.
    VCDS USER
    DCW87's Avatar
    Feb 2012
    Northwich
    36
    yeah my turbo was replaced about 25k ago, its concerning though as this only started after i put the diesel fuel treatment solution in the engine (Redex Diesel Injector Cleaner)...
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    I used injector cleaners a few times as well. Never thought that could be related. Might just be coincidence.
    VCDS USER
  1. newb, with 1.9 130 loss of power after head gasket change
    By BEELZEDUB in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th November 2012, 00:56
  2. sudden loss of power after overtaking
    By Reedswood in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th January 2012, 10:26
  3. Loss of power after first service (2.0 TDI 170 DPF)
    By Fleagle in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th March 2009, 07:41
  4. Loss of power after panel filter fitment?
    By Oranoco in forum Tuning
    Last Post: 24th February 2008, 23:40
  5. Loss of power after super-unleaded shortage :(
    By joshxs in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th October 2007, 13:30
