Sky InsuranceEM Tuning
Results 1 to 9 of 9
    Asads3's Avatar
    Feb 2013
    votex side skirts
    Hi all. I'm new on here. Anyways.... I've now got some votex side skirts 3door and am struggling to put these on. Showed a few garages in west london and no one wants to touch them.. can anyone recommend me where to go.... or can I do it myself?
    27,097
    Welcome to the site.
    Pics of said skirts?
    Asads3's Avatar
    Feb 2013
    I took of the side seals and door strip... did I just waste my time or does the skirt go there?
    Mr. B's Avatar
    English...not so good
    Jan 2012
    Bristol
    941
    You can get genuine side skirts, for only about 220 brand new. Just buy 2x Side Skirts left and right, 2x End Caps and your current Door Bottoms and sill plates can be sanded down to fit. Did it myself, real easy plug and play. I really don't like the look of those, but hey.
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    Quote Originally Posted by Snipe View Post
    They are genuine Audi parts. They are part of the votex kit which was an optional upgrade just before the s-line model was released.
    They do actually look quite decent when fitted, search my threads and although I had a sportback, you can see the complete votex kit.
    Asad, yes you have done the right thing by taking the two strips off, otherwise the skirts will not fit in place. A bit fiddly but they will go, masking tape to hold things in place, and I would give at least 48hrs for the glue to set of properly especially in this weather.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    27,097
    Yeah they look ok to fit, same basic fitment as S3 ones & as you've rightly done & been advised, remove the extterior trims to fit these in place but make sure you clean of any old residue from old trims before fitting or wont it flush & as Dan says mask tape them after fixing with sikaflex or the like & leave to cure for 24/48 hours.
    Mr. B's Avatar
    Jan 2012
    Bristol
    941
    Quote Originally Posted by Dannykn9 View Post
    Ok fair enough, but since he's make an S3 replica but the looks of it, I thought S3 sideskirt might look a bit better, rather than mix and matching body panels.
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    oh ok, didn't realise he was doing an S3 rep. I see your point now fella.
    Asads3's Avatar
    Feb 2013
    Guys i get what your saying. Spoke to Audi west london they want £450 for the pair. i got these for £95 at my door... So back to the point of fitting, are these glued on and screws either end? what about the clips?
  1. A3 Sportback Votex Side Skirt Picture??
    By dappa786 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th July 2009, 14:12
  2. how to fit VOTEX SIDE SKIRTS??
    By khalil in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th April 2009, 22:01
  3. Genuine OEM VOTEX side skirts
    By davidkoulakis in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th April 2009, 23:46
  4. Votex Side Skirts
    By Jaywoo_A3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th August 2006, 10:01
  5. fitting oem votex side skirts to my 1.9tdi 2000 a4
    By andyollie in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th February 2004, 15:12
