Following on from some earlier posts about the use of front and rear fog lights, I have found the following information in the The Road Vehicles Lighting Regulations 1989 which I assume is still current.
No person shall use, or cause or permit to be used, on a road any vehicle on which any lamp, hazard warning signal device or warning beacon of a type specified in an item in column 2 of the Table below is used in a manner specified in that item in column 3. Column 2 refers to the type of light and column 3 to the use..
(2)Front fog lamp (3) (a) Used so as to cause undue dazzle or discomfort to other persons using the road.(b) Used so as to be lit at any time other than in conditions of seriously reduced visibility.(c) Used so as to be lit when a vehicle is parked.
(2)Rear fog lamp (3) (a) Used so as to cause undue dazzle or discomfort to the driver of a following vehicle.
(b) Used so as to be lit at any time other than in conditions of seriously reduced visibility.(c) Save in the case of an emergency vehicle, used so as to be lit when a vehicle is parked.
Wrongfull use is subject to a fixed penalty fine.
