AH FabricationsBadger5
Results 1 to 17 of 17
    May 2011
    24
    Clutch on way out ?
    Hi all , driving my 2007 S3 with 63k on the clock a couple of weeks ago in 6th put my foot down and it revved up slightly , felt like an automatic. A week later accelerating from 3k revs in 6th felt a slight rise in revs then back down again . I have tested it over a few journeys since and it is now behaving normally . Could it be a one off or the begining of a clutch failing ,
    Cheers all
    autolatry's Avatar
    Jan 2013
    Yorkshire
    347
    Could be a leak in the hydraulics?
    Sep 2012
    Brum
    299
    Mate I hate being the bearer of bad news. But it's defo the clutch. Nit starts like that then just gets worse. Invest in a spec smf kit. Not cheap but a very high spec clutch which will handle a lot of punishment
    Pushing the limits..
    Jan 2011
    Australia
    1,307
    Add Sevv on Facebook
    Awesome gti make a clutch kit for it its a SMF lightweight with 4 6 puk clutch rated up to 480ft/lbs torque and there has been good reviewes on it from the 8L guys and iirc 8L and 8P 6 speed manual boxes are the same in both chassis ... i know ill be giving it a go
    the kit comes witht he MC and bolts all you need around 550 600 pounds iirc
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,320
    Quote Originally Posted by Lincoln S3 View Post
    Hi all , driving my 2007 S3 with 63k on the clock a couple of weeks ago in 6th put my foot down and it revved up slightly , felt like an automatic. A week later accelerating from 3k revs in 6th felt a slight rise in revs then back down again . I have tested it over a few journeys since and it is now behaving normally . Could it be a one off or the begining of a clutch failing ,Cheers all
    Does sound very like the clutch is getting tired.
    If you aren't going to go beyond Stg2+,then a Sachs or Loba organic clutch would be good safe choices,but the Sachs doesn't like being rageed from the start,and needs a good few hundred miles of gentle running in.
    I seriously wouldn't recommend a paddle clutch for road use(having used one before),but the Spec Stg3+ clutch is probably the best SMF setup around currently,and will handle nearly 600lbs.....it's what I use on my car.
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,047
    Yep, sounds like the clutch. Its barely believable that a modern car like this can lunch a clutch so easily. Mine lasted just 20k.
    Now:
    -MK2 Golf Gti 16V/VR6, Oak Green, Shrick, Intake, Decat, Kish Retrim, Lenso BSX..
    -BMW 335d Xdrive, Estoril Blue, fully loaded.
    Before:
    S3 (8P), Ibis, DSG, Milltek, SHARK
    BMW 320d M Sport
    S3 (8P), Sprint, REVO, H&R Springs, BBS CHs,
    Golf MK5 GTi 20TFSI - REVO Stage1, Red.
    Golf MK5 GTi 20TFSI - Std, Shadow Blue
    Civic Type `R`
    Golf MK4 GTi 18T - 200bhp, MTM ECU, Forge DV
    Golf MK3 VR6 - Cat Back
    Corrado VR6 - JAMEX
    Corrado G60 - JAMEX, BRM Charger rebuild
    etc....
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,320
    Quote Originally Posted by PaulAr View Post
    I think it was specc'd so close to the car's stock torque that it just has no reserve......the shame of it is the Sachs organic is much more robust,costs about the same and uses the same DMF.
    Jonse's Avatar
    Oct 2012
    376
    Guys with the clutch on the way out could that be a cause of hesitation?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,320
    Quote Originally Posted by Jonse View Post
    You'd simply get a rise in rpm,with no increase in speed,as the clutch begins to slip,and usually most obvious at peak torque,rather than the sort of hesitation you get from plugs/coilpack problems.
    mephisto's Avatar
    Oct 2004
    192
    Quote Originally Posted by Sevv View Post
    Interesting so this is the SMF the pressure plate and clutch?
    So not much chatter on S3 8P using SMF? Does it improve throttle response?
    Fyi my clutch started slipping for a while, day after my wife had been driving it, riding the clutch may of glazed it? Strangely not slipping anymore.
    2009 S3 8P Phantom Black
    MODS : S3 Keyring
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,785
    Quote Originally Posted by mephisto View Post
    It will create "hot spots" on your clutch plate and it'll get much worse.
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,320
    Interesting so this is the SMF the pressure plate and clutch?So not much chatter on S3 8P using SMF? Does it improve throttle response?Fyi my clutch started slipping for a while, day after my wife had been driving it, riding the clutch may of glazed it? Strangely not slipping anymore.
    Awesome's own clutch kit is a full face organic plus SMF from the pictures on their site,and not a paddle clutch.
    This will certainly make it a bit more road friendly,but there will be more rattle and thrash at idle with an SMF than you're used to.
    Jan 2011
    Australia
    1,307
    Quote Originally Posted by S3Alex View Post
    hey ALex what SMF and clutch where you using (rated at 600lbs) ? is it the loba one ? as for awesome's clutch they have an option as per what mike told me can choose which clutch to pick 4-6 paddle ...they claim there is no chatter either Westy or Welly forgot who on the 8L section gave it a go and turned out fine on his s3
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,422
    i've been using loba&sachs smf combo for a month now and it's really great kit. no chatter for now and it feels like oem. pedal was a bit harder at first but it loosen up after some miles. accelerations are violent now, and it feels like it's going to break the engine mounts.
    for the chatter i've been told that using some higher grade transmission fluid helps. but so far it's not being an issue.
    s3 Ibis White ... Build Thread
    / Black Grill / FbMfSw / Sunroof / Hill Hold / Armrest / Black Leather-Alcantara interior / Rear Parking Sensors / Heated Seats / Folding Mirrors / Cruise / Rns-e mk2 // ttrs-Brembo Brakes / 12mm spacers / Forge Short + Side Shift / 42dd's / ITG CAI / GfB DV+ / Forge Catch Can / Milltek TBE / Forge Twin IC/ Autotech HpFp / H&R ARB's / WALK / KW v3's / RS4 fpr / Loba&Sachs clutch / Revo Stage 2+ / ...
    Jan 2011
    Australia
    1,307
    Quote Originally Posted by S. View Post
    S. where did u purchase it from ? if i ask.. as i need a replacement soonish
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,320
    I use a Spec Stg3+ carbon-metallic clutch.
    Spec Stage 3+ clutch
    I seriously wouldn't bother with a paddle clutch for road use,as they do not deal with being slipped at all,and if you have a superb alternative like the Spec and you really NEED that sort of rating,then I would look no further.
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,422
    hey there, got it from my local tuner here in Croatia.
  1. Is my clutch on the way out?
    By lee111s in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th October 2009, 18:53
  2. Is my Clutch on the way out?
    By redevo1 in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th July 2009, 11:48
  3. Clutch on the way out?
    By Rich in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th June 2007, 09:56
  4. Is my clutch on the way out? [A4 1.9TDi Sport 130]
    By brixo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th December 2005, 16:48
  5. How can you test if your clutch is on its way out?
    By MingBluS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th February 2004, 18:35
