Results 1 to 15 of 15
    Nov 2012
    Blackburn
    61
    bluetooth stays on??
    hello
    just intsalled rnse and bluetooth and had coded so all seems to be working.
    i think i may have an issue though. my phone says its still connected to the bluetooth module even when im in the house and switched everything off. although the car is still within range?? is this normal?
    jasonc's Avatar
    Jun 2011
    Reading
    134
    No, not normal - Bluetooth on phone should disconnect within a few seconds of turning the ignition off.
    2008 Audi S3 Manual
    Nov 2012
    Blackburn
    61
    its still on. i think i should remove it. before it kills my brand new battery. arghh
    Nov 2012
    Blackburn
    61
    my version is 8p1862335 h44. if that helps
    Sep 2012
    Aberdeen
    36
    Could you not turn your Bluetooth off when you leave for the mean time instead of removing it? When I turn my ignition off my phone disconnects after a couple of seconds.
    Nov 2012
    Blackburn
    61
    yea i usually switch my bt off my main concern is the power drain il will have. i had something about some models being faulty thats why i got the latest one but it seems this is also faulty
    1,873
    I think you may have a coding /wiring issue, I've not heard of any of the latest models having firmware fault.
    Nov 2012
    Blackburn
    61
    i did get the plug and play wiring? do you reckon it could be that?
    1,873
    What about the coding via VCDS?
    Nov 2012
    Blackburn
    61
    yea got the coding done by quite a reputable guy. might have to go see him again
    1,873
    If he was able to code it then the CAN wires are correct so the unit should switch off with the ignition. I would check the coding.
    Nov 2012
    Blackburn
    61
    ok i will get the coding checked again
    Nov 2012
    Blackburn
    61
    defo not the module??
    Tay
    May 2012
    Warrington
    321
    I've got a feeling there is an option which is accessible from within the coding of the Telephone module to enable the phone to be continuously connected, but wouldn't have thought this would work when the car is locked.
    Nov 2012
    Blackburn
    61
    thanks for all the help got it sorted now. just bit of resetting and coding again
  1. symphony and nokia bluetooth
    By rjc in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd December 2003, 14:20
  2. SE Handsfree Bluetooth Car Kit
    By MarkyB in forum General Chat
    Last Post: 6th August 2003, 14:43
  3. MOVED: SE Handsfree Bluetooth Car Kit
    By MarkyB in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th August 2003, 17:40
  4. BLUETOOTH HELP
    By RichA3Turbo in forum General Chat
    Last Post: 8th May 2003, 22:40
  5. Does It Stay Or Does It Go..?
    By shagga in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th April 2003, 04:08
Tags for this Thread
