EM TuningVolks Autos
Results 1 to 7 of 7
    Jan 2013
    Wiltshrie
    85
    A3 2.0T maf readings Are they any good?
    A3 2.0t standard car, done a run in 3rd and 4th WOT and the highest reading i got was 143.89g/s, is this about right or ?
    thanks craig
    Jan 2013
    Wiltshrie
    85
    Any ideas?
    Jan 2013
    Wiltshrie
    85
    Bump
    Lewis583's Avatar
    Mar 2010
    829
    When in 3rd did you do the pull from ~2500rpm up to redline?
    I've just checked a log i did of mine (which as far as i know is stock) last October and I managed a peak of 169g/s at ~6300rpm
    So you may have a boost leak somewhere. Next step would be to check the boost requested vs boost actual.
    The measuring blocks I use to log boost pressure are, 002/115/118
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Jan 2013
    Wiltshrie
    85
    Thanks for response, yea was til redline and I done requested and actual boost and they do match roughly when it spools it over shoots on requested but then settles
    Jan 2013
    Wiltshrie
    85
    My mpg is averaging at 23mpg, that's me working it out, this is driving on decent roads without hard acceleration or braking, I would expect high 20's, anyone got standard maf readings or can tell me if mine is any good that would be appreciated
    Jan 2013
    Wiltshrie
    85
    Forgot to say that's also on momentum 99 and tyre pressures are fine
  1. Need new brakes, will these fit and are they any good (B7 A4 2.0TDi)
    By DJM1982 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th August 2011, 09:11
  2. Anyone used CAMSKILL for buying tyres? Are they any good?
    By DJM1982 in forum General Automotive Chat
    Last Post: 23rd February 2011, 22:12
  3. Aftermarket drl's are they any good?
    By jayhall in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th February 2011, 08:50
  4. Anyone got one of these bonnet bra's? And are they any good?
    Last Post: 2nd June 2010, 08:44
  5. Kumho tyres are they any good??
    By barters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th March 2009, 16:06
