Badger5Sky Insurance
    Apr 2012
    56
    Passenger door problem
    Right people been having some problem with closing my passenger door ever since the wind blew it wide open, when it shuts it closes lower then jolts up... Is there anyway I can fix this or do I have to go to Audi?
    Mar 2010
    Cleveland, North East
    214
    Can't remember how the doors mount on the 8P on my old 8L 3 Door the door dropped like that, sorted at a body shop by them effectively bending the door hinges back into alignment using the door as a lever, looked brutal but there is no adjustment as far as I am aware.
    Apr 2012
    56
    Cheers pal I think I might try a body shop place if not ill try Audi
    27,121
    Yeap, take to bodyshop to look at hinges or the hinge fix point on the side of the door, as may have bent/deformed that area when the wind caught it.
  1. Strange electrical problem with my front passenger door.....
    By Az in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd August 2011, 19:32
  2. passenger door problem
    By Adam-D in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th March 2008, 10:44
  3. Rear Wiper & Passenger Door Mirror Problems
    By imported_vando in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th April 2005, 09:50
  4. Passenger Window Problem
    By cclarke184 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th March 2004, 21:37
  5. Door problem....
    By dans3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th July 2003, 11:42
