JMB RetrofitsSky Insurance
    jaydav2306's Avatar
    S3 Oil Usage and Cap Gunk Advice
    Guys I own a late 2009 S3 with 37,500 on the clock, loads of history and I've serviced this car twice in 8K I really do look after it. I'm due a service at 40K which will be around June time as I don't do many miles.
    I noticed that when topping the oil up I had a little bit of gunk on the cap, now I know there are a lot of scare mongerers around but this doesn't automatically mean my head is on the way does it? It could be the fact I'm doing short journeys at the moment? Advice? To note it still drives amazing no performance loss just me in panic mode seeing the gunk
    thanks
    2009/2010 | Audi S3 Black Edition Ibis White | Black Optics Pack | Fully Loaded | S-Tronic
    27,075
    Relax its probably just condensation, clean it of, check coolant isnt black, check oil isnt very thin, I reckon its ok.
    Lewis583's Avatar
    Mar 2010
    870
    Quote Originally Posted by jaydav2306 View Post
    thanks
    There's your answer bud. I used to get a bit of mayo on my 20T due to only driving 3miles to work, however now I work a bit further away it's gone.
    Don't worry and keep truckin'
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    jaydav2306's Avatar
    Quote Originally Posted by Lewis583 View Post
    yeah the coolant seems fine, gets up to temp and level is spot on, cleaned all the gunk off, topped a small bit to just over half and went on a 30 mile run and it seems to have bought off.
    i had some on the dipstick too at the bottom around the oil level but only match stick head amount is this ok?
    need to make sure I make full use of it at weekends. Are head gaskets rare to go on a S3
  1. 2.0T FSI excessive mpg and oil usage
    By gaz j in forum A5/S5/RS5 Forum
    Last Post: 10th August 2013, 19:22
  2. Oil usage and exhaust deposits????
    By Sohrob in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th July 2008, 19:16
  3. Sump oil 'Black and thin' 1200 miles after service
    By chimmo in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th March 2004, 18:40
  4. Hello, and 1.8T advice
    By MOZIIIVR6 in forum The Welcome Section
    Last Post: 27th January 2004, 12:40
  5. Excess Oil Usage ??
    By PaulBelsham in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th January 2003, 22:38
