EM TuningChris Nott
Results 1 to 10 of 10
    Apr 2012
    56
    S-line badge for S3 grill
    Hi guys,
    Was wondering if anyone could help me I've just purchased an S3 grill for my A3 S-line and want to know if the S-line badge will fit or will it need modifying at all?
    A3Kent's Avatar
    Different Gear
    May 2012
    1,026
    How old is the car?
    09 Audi A3 2.0 TDI 170 S-Line SB 8P3
    - Full Leather - LED DRL's - BOSE - Cruise Control - RNS-E Mk2 - AMI - Bluetooth - Folding Mirrors -
    VCDS owner - A3 Grille Install Guide
    rOb_A's Avatar
    May 2010
    cheshire
    1,485
    here you go;
    before
    after
    Apr 2012
    56
    Cheers pal that's brilliant
    26,776
    Just use the S3 backplate & stick an Sline badge to the front of the S3 backplate, the S & 3 are only stuck on with double sided tape.
    Apr 2012
    56
    The cars 2007
    A3Kent's Avatar
    Different Gear
    May 2012
    1,026
    If it's a 2007 then the grille Rob has pictured above is not the same as yours (this is a 2008+ Facelift grille). The 2007 should already have a specific S-Line badge for the front grille so i'd imagine it's a straight swap for the S3 one (therefore easier than above). Is the grille you've purchased a genuine OEM one?
    Apr 2012
    56
    Yeah it's a genuine OEM one pal
    A3Kent's Avatar
    Different Gear
    May 2012
    1,026
    Should be a case of just unclipping the S3 Badge and clipping the S-Line one on then I would think. Have you tried removing the S3 badge yet? Does it look the same shape as this?
    Apr 2012
    56
    I'm just waiting for it to arrive from the pictures it looks the same
  1. How to put S line badge on facelift grille?
    By sting3r in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd September 2012, 08:16
  2. Is the S3 front grill badge a straight swop for the s-line badge?
    By crypric23 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th September 2009, 10:26
  3. Prices for S-line badges for an A4
    By technics100 in forum Parts Requests
    Last Post: 15th July 2009, 13:21
  4. Quattro badge for front grille?
    By Cossie_boy in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th May 2007, 21:49
  5. Installing S-line badge on Grille
    By pav-g in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st January 2007, 23:16
