AH FabricationsEM Tuning
Results 1 to 9 of 9
    Jan 2012
    SW London
    751
    VNT clean on PD170 help - Mr. Muscle method
    Just wondering if anyones successfully done this on the PD170? After reading the threads for the b5 and b6 a4's with the 1.9 and 2.5 tdi lumps I've been wanting to do this with mine.
    I know for sure its the case that the vanes aren't free to move properly, i'm getting overboost and limp mode in 3rd 4th or 5th if im over 3000rpm with my foot down. Under 3k the car still pulls well, after that it feels like its struggling as if the DPF is blocking up (which was my initial thought as to what the problem was, but after a long drive it was no better). I've also played around with the actuator to get it moving a bit more freely and the car instantly responded better but after about 20 miles or so it was back to normal.
    My problem with this method is the following, on the guides for the B5 and B6 engines the turbo is mounted lower than the exhaust manifold. Whereas (at least im fairly certain) on the PD170 and most likely the PD140 too, the turbo is mounted above the exhaust manifold. So am i right in saying that if i was to put mr. muscle in, it would leak down into the exhaust manifold and potentially into the engine too? And as mentioned in those threads it's only safe to use on the cast iron (Exhaust side) of the turbo and nothing else.
    I really don't fancy trying to take the turbo off myself, seems like a hell of a job. Does anyone have any other (cheap) suggestions if this is definately not an option?
    26,734
    The only sure fire way of getting them clean is to remove, strip, clean & refit, Mr Muscle is a temp job that may not even work or for long, so I would do it properly or you could be back to square one in a month or so.
    Mar 2010
    Cleveland, North East
    200
    Agree with NHN, even then, stripping down the exhaust side of the turbo has plenty of scope for error if you don't know what you are doing.
    If I was that far in and the car has done any kind of mileage, given that the PD170 is a proper c*ck on to remove the turbo on in terms of removing the DPF I would be replacing the turbo with a recon unit.
    In summary - Don't waste your time just replace the turbo, after that stop driving like Miss Daisy and the VNT problems will go away.
    Jan 2012
    SW London
    751
    Quote Originally Posted by Cyrix View Post
    Thats just it, i have lead foot syndrome but the problem still came about. The turbos been changed once before by the previous owner so im not certain that its definitely in need of a change. I do understand where ur coming from but i dont think its necessary to change it completely seeing as the rest of it is still ok.
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    tdi-man's Avatar
    Jul 2009
    1,587
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs / Oil catch can
    233 bhp - 309 ft lb - 419 nm
    FLYWHEEL + HELIX CLUTCH KIT FOR SALE
    Imteyaz's Avatar
    Oct 2008
    Warwickshire
    524
    Nick from R-Tech has some youtoob vids that may be helpful (their based on the MK4 Golf TDI so should be similar I imagine).
    Failing that, if you're not too far away from him (Hinckley, Leicestershire), let him do the work for you.
    Imteyaz.
    Jan 2012
    SW London
    751
    Seen these videos already thanks. If i could get the turbo off easily enough id definitely be cleaning it myself but as mentioned by before its not the easiest thing to do on this car. And hinckleys about 100 miles from me
    VCDS User
    Jan 2012
    SW London
    751
    Quote Originally Posted by tdi-man View Post
    Havent come across this yet but if its as bad as i think it is its gonna take some serious cleaning power to help shift it. Will look into it some more tho, cheers mate
    VCDS User
    tdi-man's Avatar
    Jul 2009
    1,587
    wynns is normally good stuff to use i was thinking of doing mine say once a year
  1. Car wont start after cleaning starter motor - help!
    By ptr in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th August 2010, 10:09
  2. cleaning up bodywork help??
    By nath-w in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th April 2009, 21:43
  3. HELP Mini cleaning
    By paul_a3_tdi130 in forum Detailing
    Last Post: 19th December 2008, 11:39
  4. What is a VNT on a turbo and anyone know how to clean it?
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd February 2006, 22:47
  5. Help please - 1996 A4 1.8T MAF sensor cleaning ?
    By philwest in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th March 2004, 23:59
