Badger5JMB Retrofits
Thread: More problems
    autolatry's Avatar
    Jan 2013
    Yorkshire
    347
    More problems
    I have oil in my water and water in my oil.
    Im not losing water but I am blowing white smoke.
    Do you thinks it's worth changing the oil cooler or just get it booked in for the inevitable HG replacement?
    27,097
    So the oil cap has allot of mustard then & coolant reservoir is black?
    autolatry's Avatar
    Jan 2013
    Yorkshire
    347
    There was mustard the other week but it hadn't come back since.
    I changed the coolant a couple of weeks ago (with the correct pink coolant) its now dark brown.
    The dip stick has very runny thin oil on it quite high up the stick. I changed the oil in November with the reccomended oil.
    Any ideas on labour time for a HG? I was going to compression test the engine the other week as well but the draper compresion tester didn't fit the engine.
    autolatry's Avatar
    Jan 2013
    Yorkshire
    347
    I do smell burning oil after driving 15 miles or so.
    So if the oil cooler was crackered and wasnt cooling the oil would that make it thin?
    27,097
    Its almost certain then, what engine code is it?
    autolatry's Avatar
    Jan 2013
    Yorkshire
    347
    BDB. I'm starting to think I've bought a pup. Lol.
  1. More problems argghh!! misfiring on idle....
    By will.f_1.8t in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd November 2009, 16:01
  2. More Problems - Starter Motor this time
    By d4mo in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd May 2009, 17:05
  3. New gearbox and clutch kit. More problems....Please Help!
    By bhavin1986 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th October 2008, 07:13
  4. MORE PROBLEMS
    By AUDI TURBO in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st January 2008, 18:11
  5. more problems
    By petewon in forum General Technical / How To
    Last Post: 22nd July 2006, 14:36
