Sky InsuranceBadger5
Results 1 to 9 of 9
    Jul 2012
    S3 problem when accelerating
    Hi,
    I was accelerating hard before in 3rd gear and revs were getting up and then it felt like I slammed on the brakes, not just a loss of power, so I came off the accelerator. It drives normal at normal speeds and sounds okay, it did this twice though, didn't try a 3rd time.
    Any ideas what this could be?
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,786
    Sounds very much like the clutch I'm afraid!
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    Jul 2012
    Thanks for quick reply, how much am I looking at for a new clutch out of interest?
    Unit20 are about 10 mins away from mine so will give them a call in the morning
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,786
    Quote Originally Posted by ChrisG89 View Post
    This is a really good website and is where i got my DMF+Clutch (always replace both) from, its actually a motor factors (sutton i think), but i went there out of urgency and they seemed nice enough
    Buy AUDI S3 2.0 2007 flywheel online and save | Buy Parts By-------- £274.43
    Luk Clutch kit there too if your interested.
    Buy AUDI S3 2.0 2007 clutch kits online and save | Buy Parts By ------- £132.62
    ignore the 2007 year of car shown, they're all the same.
    I've shown the more expensive one that contains release bearing etc, might aswell change it for the sake of a few quid and it should be included in the labour costs anyway.
    Total cost of parts = £407.05 inc VAT.
    6.5 hours is the quoted time for this job.
    Average independant, What £50 an hour? so £325 labour.
    Approximately With Everything Fully Fitted = £732.05
    May 2012
    RETFORD, NOTTS
    1,753
    Sounds more like loss of a spark. Clutch slip would continue revving and go nowhere fast, but not feel like you slammed the brakes on.
    I had this issue only once on a calibra turbo with wrong gaps. So id start by checking plugs/coils.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,786
    I know when my clutch started to slip in 3rd/4th gear i was 'pushing on' and it felt like id be shunted up the backside.
    Loss of spark would have put some twinkle lights on i'd have thought on the dash, although, we cant rule anything else out.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,354
    Hi,
    If the revs were rising without any increase in speed,then the clutch is likely to be slipping,and the other thing is plugs if they're getting a bit tired...
    That shows up as a misfire and hesitation under load.
    Sep 2012
    Brum
    299
    Been there done that. It's the bloody clutch mate. Spec clutches are ace.
    Jul 2012
    It shouldn't be the plugs as these were changed when it had a full service on the 31/07/12 by Unit20
  1. problems when accelerating ???
    By solarstu13 in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd January 2013, 17:55
  2. Juddering when accelerating - Engine Mgt light on!
    By S3Si in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th May 2006, 14:26
  3. HELP ! A6 TDI 130bhp keeps losing power when accelerating
    By tfox in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 15th November 2005, 09:48
  4. Problem when braking
    By rickparmar in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th May 2004, 01:58
  5. Lack of power when accelerating
    By shelley in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th April 2004, 11:22
