Badger5EM Tuning
Results 1 to 9 of 9
    May 2011
    please help!!! A3 TDI wont start!
    Audi A3 2.0 TDI Sport -
    Engine is starting and straight away is switching off. Put on diagnostic machine and the following fault codes are appering:
    18051 - Please check DTC memory of central eletric ECU.
    18353 - ???
    18358 - ???
    18045 - Data bus powertrain missing message f. central. eletric control
    18043 - Data bus powertrain missing message f. all wheel drive control
    17978 - Control Module Locked
    Cleared codes then these codes apeared:
    18058 - Data bus powertrain missing message fr. instrument panel ECU
    18045 - Data bus powertrain missing message f. central eletric control
    18043 - Data bus powertrain missing message f. air conditioning control
    18353 - ???
    17978 - control module locked
    Car was starting fine before. i was checking the fuses as the ABS light was on and a fault 00668 - Supply Voltage Terminal 30 was showing. thi fault has now gone :D but the car wont start
    please help.
    Thanks in advance :D
    May 2011
    i also cant track online what fault codes 18353 and 18358 are if any one can help also
    27,099
    Does the car turn over just wont kick into life or its not even turning over?
    May 2011
    cars turning over and starting instantly, but appears to immobilise.
    Jun 2011
    Great Melton Norfolk
    1,349
    What diagnostic reader are you using?
    27,099
    Then thats the immo system problem then, if it kills after 2 seconds or so.
    May 2011
    all it says on it is vagscanner VAGS30 can VW/Audi code reader Autel.
    its not actually mine. i borrowed it from a mate
    May 2011
    so how do i rectify this??
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by a3 fkv View Post
    I don't think you can without specialist equipment not available to joe public.
    If the immo. is the problem then it needs reprogramming with special ( secret) codes available only from Audi Germany or indies. with the right kit !
  1. Please help, car won't start
    By OllyS4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th July 2012, 16:18
  2. PLEASE HELP A3 TDI NOT STARTING
    By MAXDEX in forum General Chat
    Last Post: 8th November 2011, 07:36
  3. help plz car wont start
    By bono in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th February 2011, 18:04
  4. Help B7 Cabriolet wont start!
    By Fabian1999 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 5th December 2009, 23:41
  5. a4 tdi ,wont start
    By t2myd in forum Diesel forum
    Last Post: 16th July 2008, 14:24
