Chris NottAH Fabrications
    Jan 2013
    Wiltshrie
    85
    P0441 fault evap emission control system
    I have this fault on my car, I cleared the dtc and it re-appeared. I have done a search and seems a common problem and people replacing the n80 valve but a lot of people continue having problems and they don't seem to fix it 100% then end up just leaving it, so before replacing parts for the sake of it my question is can you physically test the n80 valve? If assuming I should check the pipes for splits, any other advise would be appreciated
    Sep 2012
    Grimsby, Lincolnshire
    72
    I had this fault a few weeks back, I fixed it by removing the n80 and giving a couple of squirts of WD40.
    I believe you can test the N80 if you have a full copy of VCDS.
  1. P0441 evap emission control sys: incorrect flow
    By bigblokey0 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th January 2012, 15:56
  2. Emission Control System Fault
    By amimmortal in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 26th December 2011, 17:54
  3. Emission Control System fault indicator
    By amimmortal in forum Diesel forum
    Last Post: 29th January 2009, 21:42
  4. Emission Control System light's on.
    By dkelly in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th July 2007, 10:02
  5. Emission Control System
    By migzy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th May 2007, 14:50
