Monster MotorsportBadger5
Thread: cleanng TURBO
    tdi-man's Avatar
    Jul 2009
    1,609
    cleanng TURBO
    stripping engine soon for a rebuild so am thinking is it worth cleaning my 15 month old turbo at the same time if so what to use ?
    thanks
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm
    Jan 2013
    Wiltshrie
    85
    no harm in cleaning it, the most common turbo cleaner I know is innotec turbo cleaner, normally around £30-40
    Oct 2012
    492
    mr muscle £3
    T3nnant's Avatar
    Jan 2013
    Newcastle
    363
    brake cleaner...
    Jack_tdi's Avatar
    Mar 2012
    Cumbria, England
    281
    cleanng TURBO
    Quote Originally Posted by A3Craig View Post
    If you use innotec make a better blank because the paper one supplied is ****ing ****e!! Use something that doesn't absorb moisture (tin foil ,Perspex etc. )
  1. Logging turbo boost with VAG-COM
    By Ram in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th January 2009, 22:23
  2. Turbo noise
    By AndybS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th July 2003, 21:10
  3. turbo hose set
    By waynehiscock in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th May 2003, 23:24
  4. Hot Turbo Pic
    By mramage in forum Other Brands & Models
    Last Post: 23rd March 2003, 23:36
  5. CLIFFORD Car alarm (Turbo Timer thing)
    By A4Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2003, 13:03
