Help Required: 2009 A3 - Rear Speaker Trouble
Brido1888
NULL
Folks,
got a farting/crunching/squelching noise coming from my rear passenger side speaker & it's annoying the life of me...
Anyone ideas of how this can be remedied? Anyone had similar? Can I simply buy another speaker & swap it? How difficult will it be to replace?
B
Swap with other side to be sure its the speaker 1st, then if moves to other side, get a replacement speaker.
How difficult a job is it to get to the speaker? Do you know of any guides/videos which may help, im a complete novice at this kind of stuff
And do you know of the best place to buy a replacement?
cheers
Door card of via some torx headed bolts at bottom of the door & behind the window switch trim, then pop of the plastic clips, unbolt speaker & unplug the connector, swap across & test.
Buy new from audi.
If it seems a bit daunting, then I can do this all, location dependent.
