EM TuningMonster Motorsport
Results 1 to 13 of 13
    Sep 2012
    Aberdeen
    36
    Do I have Bluetooth?
    Hi folks,
    i have an Audi a3 170 TDi. I was wondering if the Bluetooth module comes standard with car? I haven't checked under the seat yet but I thought I would ask before I check at the weekend. I have the double din standard head unit if that helps?
    I appreciate any help,
    Jan 2013
    159
    Best way is to turn car on and search for bluetooth devices with your phone.... I didnt know either till i did this!!
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,520
    do you have a cradel in the arm rest or on the dash ?
    have you tried to connect your phone ?
    Sep 2012
    Aberdeen
    36
    Thanks mate ill try this in the morning.
    cheers
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    It's not standard. Best thing to do is search for it from your mobile to see if Audi UHV or similar appears.
    09 Audi A3 2.0 TDI 170 S-Line SB 8P3
    - Full Leather - LED DRL's - BOSE - Cruise Control - RNS-E Mk2 - AMI - Bluetooth - Folding Mirrors -
    VCDS owner - A3 Grille Install Guide
    Sep 2012
    Aberdeen
    36
    I had a cradle on the dash for the 4s when I had it, I have now got the 5 but when I try to connect like I used to it doesn't work??
    27,114
    As you fitted the I4 cradle in dash, then it will have BT.
    Sep 2012
    Aberdeen
    36
    Ok just popped out and tried to connect via my phones Bluetooth but did not find any devices? I haven't got the cradle anymore could that be an issue?
    27,114
    Where was the cradle fitted, was it an audi accessory?
    Sep 2012
    Aberdeen
    36
    It was fitted to the left of the head unit on the dash. Yes it was an audi accessory and fitted by them.
    27,114
    So there is no dash bracket fitted into the dash still, sounds like it was aftermarket not genuine audi, so doubt its got oem bt.
    You're way up there in Scotland iirc, havnt had chance to get up that way to install anything atm, otherwise I'd certainly be able to sort that for you.
    Sep 2012
    Aberdeen
    36
    There is a dash mount and it was an OEM audi iPhone 4/s cradle with part no. 8T0.051.435.F.
    27,114
    Show us a pic of the dash as it is it.
  1. Does my concert have Bluetooth
    By Easygoingdave in forum Retrofit
    Last Post: 15th January 2014, 07:03
  2. Does anyone have the AMI Bluetooth adapter?
    By Vertigo1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th December 2010, 20:33
  3. Car with armrest cradle, does it have bluetooth?
    By Starkey in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 16th July 2009, 18:52
  4. Have you got a Snooper S5?
    By amoffat in forum General Chat
    Last Post: 9th January 2003, 15:44
